'07 gs350 a/c compressor shaft
Old 12-30-16, 11:52 AM
barbarajor
barbarajor's Avatar
Default '07 gs350 a/c compressor shaft
'07 GS350, 90,000 miles. I shorted the alternator hot lead while changing alternator. Blew fusible link and starter relay. I replaced the fusible link and starter relay and everything worked again, except the a/c. A/C blows only hot air. Compressor turns and blower works fine. I took it to the local dealer, who said the a/c compressor shaft was broken. Cost to replace $1,750.00. It seems like too much of a coincidence that the shaft just happened to break while I was replacing the alternator and a few electric parts. It worked fine before I changed the alternator, and was not started again until all work complete. Has anyone had a similar experience? Seems like it should be related to the electric problem, since it worked before I started working on it.
user 528962307
05-30-19 03:49 PM
Jenju10
01-22-19 12:47 PM
barbarajor
12-30-16 11:58 AM
starstreak
12-30-14 04:46 AM
burny
06-11-13 08:45 AM
Quick Reply: '07 gs350 a/c compressor shaft
