CEL and trac light on, codes inside
Old 12-21-16, 05:56 PM
feaky
feaky's Avatar
Default CEL and trac light on, codes inside
Hello, I drive a 2009 Lexus gs350 161000 miles on it and today the cel and trac lights turned on so went to my local autozone and they gave me these codes:
P0172 and P0175 which are system too rich on both banks and P1170 which is the fuel performance/port injector.
They also gave a list of probable causes for the MAF sensor, faulty heated oxygen sensor, ECT sensor fault or fuel injector or pressure regulator leaking.
I went ahead and bought a MAF and air filter just in case but I'm curious to know if anyone else has had this problem and how it was fixed.
EDIT: Just turned on the car and the warning lights went off, not sure if I should bother returning the MAF if it's a system error or just go ahead and replace it.
Old 12-22-16, 11:50 AM
XxGoKoUxX
XxGoKoUxX's Avatar
I'd return the MAF sensor and probably clean your current one.
Have you done any mods whatsoever to your car? (performance-wise)
AdamProve
03-07-19 04:15 AM
AdamProve
ES - 5th Gen (2007-2012)
01-24-19 05:29 AM
AdamProve
01-23-19 08:29 PM
AdamProve
09-15-18 05:12 PM
UNOHOO
IS - 1st Gen (2001-2005)
08-05-09 11:41 AM
Quick Reply: CEL and trac light on, codes inside
