Leaking Tranny Oil from driver Side (Manual Valve Seal Info Needed)
Old 12-20-16, 08:04 AM
4ringsa6
4ringsa6's Avatar
Default Leaking Tranny Oil from driver Side (Manual Valve Seal Info Needed)
Hi guys,
I dont drive my 07 GS350 much and is usually parked for 5 days before use. So I Noticed A think oily small quarter size oil on my garage floor. Positive its not coolant as it has a "geary" smell, its pink and thick.
My lexus dealer told me there was a slight leak on a seal (no other explanation) IM assuming its the seal near the driver side transmission pan its called the Manual Valve seal.
Im getting conflicting results on my research i have two part numbers: 9031112002 and 90311A0009. What are the differences? Which is correct for my 07 gs350?
Also i saw that there is a box that is covering this seal correct?
Does this require dropping the transmission pan, fluid, ect?
Dealer quoted me 700 to drop the pan, replaced fluid, pan gasket, the seal. Is this reasonable? Is dropping the pan necessary to replace the seal? I aleady did a service on my transmission and dont need to change fluid only the seal.
Old 12-20-16, 11:05 AM
ibidu1
ibidu1's Avatar
Try this! go under the car grab a 10mm socket and tighten the bolts on the transmission and oil pan. Then use some degreaser and spray the leaking oils off the engine. Then after a week or so look under the car and see if theres a leak or not and if there is you should be able to spot it better once cleaned
ServerTech (12-20-16)
Old 12-20-16, 02:39 PM
Sodium
Sodium's Avatar
Yep, this is a good place to start
Just be sure not to tighten the bolts too much – factory specs for the transmission pan bolts is 39 inch-pounds, so be very careful if you're not using a torque wrench
Old 12-21-16, 06:59 AM
4ringsa6
4ringsa6's Avatar
The bolts are well torqued. It is leaking on only on the middle to end of the pan towards exhaust on the driver side. The rest are dry
TLPLEXUS
ES - 5th Gen (2007-2012)
33
08-02-23 09:08 AM
DanIrl
06-05-18 08:50 AM
SammyV90
03-01-16 06:20 PM
4ringsa6
01-28-16 12:31 AM
94LSon20
12-08-10 10:27 AM
Quick Reply: Leaking Tranny Oil from driver Side (Manual Valve Seal Info Needed)
