headlight pentagon adjustment screw removal
Old 12-01-16, 10:56 AM
lexusisgs
lexusisgs's Avatar
Question headlight pentagon adjustment screw removal
Hi there,
does anybody know where we can find special screwdriver with pentagon bit in order to adjust head light levels .
I have used screwdriver with torque bit T-27 but it will slip and ruin screw by it self so in the future will b hard to adjust it.Also that screw with that special pentagon head needs to be removed when u replacing ballast in order to remove big connector.
​​​​​​​thanx in advance
Old 12-01-16, 03:00 PM
MX73
MX73's Avatar
Sears should have them. Maybe even a Harbor Fright if you have one in the area. As far as adjusting the headlight, it should be a #2 or #3 Philips head screwdriver unless they replace it with an aftermarket. The adjustments is inside the fender, so you need a very long screwdriver.
lexusisgs (02-04-17)
Old 02-04-17, 10:48 PM
lexusisgs
lexusisgs's Avatar
This is the one ....big issue to remove.
Old 02-04-17, 10:49 PM
lexusisgs
lexusisgs's Avatar
still looking for screwdriver with this pentagon tip.
Old 02-05-17, 10:45 AM
tcr101
tcr101's Avatar
That is not the headlight adjustment screw. You will be able to adjust levels with a Philips screwdriver
Old 02-06-17, 08:09 AM
ReLexing
ReLexing's Avatar
That is an Allen Key bolt. And like tcr101 stated," It's not the adjustment screw.
Old 10-27-20, 02:10 PM
obsessed
obsessed's Avatar
Hi there,
thanx in advance
Lexusisgs: There is no such thing as a pentagon screw, the name is Allen. And the T-27 is a Torx, not torque. The Allen screw does not adjust the lights.
Old 10-29-20, 11:35 AM
PauloFR
PauloFR's Avatar
This is what I thought: as per the manual, the adjustment screws are 3 Philips screws. One for the low beam vertical adjustment, one for the low beam horizontal adjustment and one for the high beam vertical adjustment.
JamesG
07-05-13 10:14 AM
Jodar96
12-10-08 02:35 PM
smmart
GX - 1st Gen (2004-2009)
06-09-08 07:05 AM
midwstboy
SC- 1st Gen (1992-2000)
08-08-06 10:51 PM
Quick Reply: headlight pentagon adjustment screw removal
