07 GS450H replacing/fixing transmission oil pump controller
Old 08-07-16, 09:30 AM
lexusdog
lexusdog's Avatar
Default 07 GS450H replacing/fixing transmission oil pump controller
Having an issue with a GS450H that has a P2797 code. Which says oil pump controller malfunction. I read another post that said this is a 3k part from Lexus, but it can be rebuilt. My question is, has anyone had success removing this oil pump and having it rebuilt at a machine shop? Also, do I have to drain the trans fluid to remove this unit? If so, how do you drain and refill the trans since there isn't a dipstick. Are there fill and drain plugs on the side of the transmission case.
Any advice or how to instructions would be greatly appreciated.
Thanks!
Old 09-02-22, 08:41 AM
Chrisibra
1st Gear
Chrisibra's Avatar
I know it’s years later but were u able to deal with this. I have same issue.
Old 09-04-22, 11:09 PM
jaxwins
jaxwins's Avatar
There are 2 plugs, one for drain one for fill. You need to drain oil before open that pump.
For removing that pump, is easy operation, only few screws. There are 2 problems with that pump : electric motor bearings , which are inexpensive and relatively easy to replace, and/or hydraulic pump itself ( can be noisy, or cannot build enough pressure). In this case , good luck finding someone for rebuild. You can buy a used one too.
Old 09-13-22, 09:22 PM
mr. tetsuo
mr. tetsuo's Avatar
this job took me 4 weekends to complete and i still occasionally get the error code. yes you have to drain trans fluid. its a PITA but its fixed and running. used part on ebay is 1.5k or a new one was like 3k. replaced the 2 bad bearings for $80 in parts
genji
CT 200h Model (2011-2017)
10-02-23 12:43 PM
lxsomatic
Hybrid Technology
10-03-16 05:07 AM
IM QUIKR
IS - 1st Gen (2001-2005)
02-10-10 02:31 PM
BananaGS
Maintenance
14
08-05-02 01:13 PM
Quick Reply: 07 GS450H replacing/fixing transmission oil pump controller
