2007 lexus gs tire pressure light on
my car dont have swicth there!!! also i cant find the door lock unlock buzzer volume control switch too....
my older lexus had tht switch.... any other advice!
there is a Reset/Set button on the driver side. in the foot area nest to the small fuse box. there is no way to see is while sitting in the driver seat you have to get out of the car and look under the driver side dash.
i thought my car didnt have one until i was cleaning the car a couple of days ago and saw it.
to reset the tire pressure range fill all the tires to the desired psi then with the car start press and hold the Reset button until you see the warning and tire pressure light turn on release the button when the let goes out.
Good luck.
Good luck.
fisherman5
i installed 5 new sensors i bought on line, took my RX350 2007 to Lexus to have them activated to the Lexus. They said i needed to give them the serial numbers of the sensors and it would cost me $220 to get them programed once i gave them the serial #. So i went to Less Schwab, they used their sensor activator and programed all 5 sensors for $22 plus tax. So if you replace your sensors go to Less Schwab to get the programed to your auto and save a bunch. And you do not need the serial #. They also can tell you what tires have a bad sensor.
Good luck.
Good luck.
aachowhan
11-06-23 02:38 PM
