Suspension / steering issue
Old 03-23-16, 07:23 AM
Andyb63
Andyb63's Avatar
Default Suspension / steering issue
I had new springs and dampers fitted about 6 months ago. KYB shocks and Eibach springs to lower slightly. All fine for a few months. recently I have noticed the car'wandering' a bit and when on full lock get a very noticeable 'clunk' noise.
No sign of dampers being the problem and with the clunking and wandering I suspected a ball joint or tension rod. Garage has had it for a week and can't find anything wrong with it ( not a lexus garage).
So, anyone experienced something similar?
Old 03-23-16, 04:56 PM
Steve2424
Steve2424's Avatar
How do the struts and strut mounts look? Also, did you get a wheel alignment done after having the work performed? I'd look at the first query, and then have the second one done if it wasn't.
Old 03-23-16, 05:50 PM
ibidu1
ibidu1's Avatar
Theres a huge bushing in the front lower rear of the a-arm bushing. Its cheap and easy to fix and should help.
Old 05-11-16, 08:56 AM
Andyb63
Andyb63's Avatar
Thanks for this. Do you have a picture so I can be sure of which bit I am looking for.
Old 05-11-16, 12:44 PM
ibidu1
ibidu1's Avatar
http://www.ebay.com/itm/LEXUS-OEM-IS...tW6ltO&vxp=mtr
Also post your alignment specs too much negative chamber can be a problem
nytoy
Suspension and Brakes
19
09-19-23 09:14 AM
gabzor
02-26-17 05:53 PM
boris
10-14-10 12:22 AM
JLund
11-11-08 07:11 PM
moons70
05-24-07 06:42 AM
Quick Reply: Suspension / steering issue
