What could be wrong with my 06gs300
I have a 2006 gs300 i had a code that had to deal with the computer . so I replaced the (ECM) and the (OXYGEN SENSORS)
At lexus dealer. Now the car is shiffting strange when replacing the ecm
P0751
How do I know if my tranny is bad?
When I'm at a full stop and hit the gas it has a late shift and jumps when grabbing 1st gear. It will happen on 2nd gear as well. I recently had the the ecm and Oxygen sensors changed because had a code and engine light on p0751. Lexus couldn't tell me anything about my tranny. I thought it was my ecm causing the late shift problems but it wasn't that .
hmmm wel i get that same error and i do not know which O2 sensor it is. do you know which one they replaced? but for the transmission shifting same thing happened to me had the fuel recall then next min i couldnt shift past 3rd. Error P0761 Solenoid C and P2714 Pressure control solenoid "d" came up found out it was S3 and SLT solenoid but honestly it can be from dirty trans oil. I tested the bad solenoids but the ohm read correct but for good measure just going to swap them out. give it some time and you will get some error codes but normally with 1st-3rd i found it out can be 4 of the big solenoids
http://club-lexus.ru/forum/viewtopic...50&per_page=50
GS4.0
18
02-28-09 07:40 PM
