HELP! 02 oxygen sensors
Guys, searched around but found no part numbers for the oxygen sensors.
So, someone knows how many oxygen sensors and which are the part numbers the 06 GS 300AWD has?
Can you buy Denso instead of the Toyota branded parts?
Many thanks
Many thanks
89465 8946530830 SENSOR, OXYGEN. SENSOR, OXYGEN; LH
GS300 (GRS195) $169.96 8946530830
89465 8946530720 SENSOR, OXYGEN. SENSOR, OXYGEN; LH
GS300 (GRS195) $177.16 8946530720
I am getting those 2 different part numbers for the left side and two more
89465 8946530820 SENSOR, OXYGEN. SENSOR, OXYGEN; RH; RH & LH
GS300 (GRS190)
GS300 (GRS195) $154.45 8946530820
89465 8946530710 SENSOR, OXYGEN. SENSOR, OXYGEN; RH; RH & LH
GS300 (GRS190)
GS300 (GRS195) $177.16 8946530710
So, 4 sensors total? Which one is bank 1 sensor 1 ?
GS300 (GRS190)
GS300 (GRS190)
Update
The A/F sensors were needed per the codes.
This codes appeared on the scanner. P0172 and P0175.
OK, so, after searching for info, first I cleaned the MAF sensor with a MAF cleaner.
I also changed the spark plugs. Still have the codes and have very high HC levels (and high CO)
Then, bought new and replaced the old A/F sensors of both banks.
They work perfect and the HC levels at high rpms really improved but still have high HC levels at idle. And the codes also reappeared.
What else to do guys? Any ideas
