Side Mirrors
Old 09-29-15, 03:51 PM
frotiss
frotiss's Avatar
Default Side Mirrors
Hey guys my 07 GS350 after coming out of Reverse the mirrors don't tilt back to the original position and sometimes it don't tilt down far when put in reverse any help please Thanks
Old 09-29-15, 05:48 PM
sprtn131
sprtn131's Avatar
My 06 gs300 does the exact same thing. I think it's just a glitch not sure if there is a solution
Old 09-29-15, 05:56 PM
Broncosi
Broncosi's Avatar
446 posts and you didn't search for this before posting?! haha tisk tisk!
I have this problem all the time. People's explanation is that the gears aren't well made and strip so the mirrors fail at tilting all together eventually but start by not returning to the correct position . . . ever (for me at least). The fix? People either replace the whole housing with gears or take it apart and replace the gears inside.
If you want to or care about it, I would open the mirror assembly up and replace the gears and when you put the mirror back together, use the newer, direct fit covers with turn signals on them.
Old 09-29-15, 08:43 PM
pman6
pman6's Avatar
solution is to stop using the auto tilt
Old 09-30-15, 04:48 AM
IXI187IXI
IXI187IXI's Avatar
i never turned mine on because of this reason
Old 09-30-15, 05:39 AM
Broncosi
Broncosi's Avatar
I agree that the work around is to stop using them. My question is, why would Lexus half *** something like this? If those gears weren't made for use on a regular basis, then don't give the ability to fold the mirror in at least.
Old 09-30-15, 10:42 AM
IXI187IXI
IXI187IXI's Avatar
for the same reason why everything is run off electronics now a days, so when it breaks you either have to 1) buy a new one or 2) take it somewhere for repair. why make something that will never break? your losing money if you do that
Old 09-30-15, 11:05 AM
Broncosi
Broncosi's Avatar
Insert "reminiscing the good old days" here
I was just discussing with a coworker yesterday how we could both fix any issue with our first cars ourselves. Now you open a hood and everything is hidden under plastic.
Old 09-30-15, 11:56 AM
IXI187IXI
IXI187IXI's Avatar
hence why i still love my older cars i have. all mechanical to fix, hardly anything electrical
Old 09-30-15, 10:37 PM
pman6
pman6's Avatar
I agree that the work around is to stop using them. My question is, why would Lexus half *** something like this? .
because the 3GS was a giant experiment and not tested enough.
Seems like an endless list of things that break in this car.
Old 10-01-15, 12:10 AM
Mesca
Mesca's Avatar
No, the actual solution is to open your drop-down menu box and make sure you have the green light either on L or R. If it's on neither, it will not angle down when you put the car in reverse. Try that and see if it fixes your problem!
Old 10-01-15, 02:24 AM
IXI187IXI
IXI187IXI's Avatar
that doesnt resolve the issues though. whether its on L or R the issue is not returning back to its original position when you shift into D
Old 10-01-15, 01:10 PM
Broncosi
Broncosi's Avatar
Exactly. My mirrors are pointing a different angle everyday. I never know what I'll be looking at when I get in to drive to work every morning.
getafewliv
08-27-14 04:07 PM
Alex818
06-06-13 05:22 PM
Charlie088
07-08-11 02:10 PM
xssax
11-15-10 09:29 PM
coreyco
05-29-09 01:18 PM
Quick Reply: Side Mirrors
