06 gs430 blown motor?
Old 07-04-15, 12:13 AM
njumongkol
njumongkol's Avatar
Default 06 gs430 blown motor?
I was driving and the check engine light came on, vdc light, and the temperature gauge went straight to cold like the car was turned off but the rest of the gauges were working. So then I exited the freeway and the car started shaking and then turned off. I popped the hood and steam was coming out of the hood. I didn't know the car overheated because the temperature gauge didn't work. Now the car won't start, is there a safety thing that I need to reset if it gets too hot? It got so hot my reservoir cap melted and the radiator cap blew. When I looked up the check engine code it said, "P0117 ENGINE COOLANT CIRCUIT LOW INPUT". I checked plugs and all they are all dry. I checked the oil dip stick and there is no coolant in the oil. Any ideas??
Thanks.
Old 07-05-15, 04:36 PM
Gotcha350
Gotcha350's Avatar
If it got as hot as you are describing then the motor could have seized.
Might want to start by seeing if the motor can be turned freely by the crank.
You had to have noticed something...if you knew the gauge wasn't working then that's on you...but it is a chance that something broke causing the car to just dump the coolant....that's what I would start looking for.
Old 07-06-15, 09:36 AM
LexusLive
LexusLive's Avatar
I can't imagine how badly you'd have to abuse an old 4.3 V8 to make it seize.
Old 07-07-15, 11:36 AM
Gotcha350
Gotcha350's Avatar
If it seemed to get as hot as he described...not much....its still an aluminum engine...
Old 07-07-15, 11:45 AM
sha4000
sha4000's Avatar
Where are the pic?!!
Jkuutys
06-05-16 12:16 PM
mcintosh1
08-03-15 09:20 AM
cobalt91
05-22-14 07:05 PM
818GS
10-07-12 11:37 PM
joshthorsc
Performance & Maintenance
06-19-06 10:52 AM
Quick Reply: 06 gs430 blown motor?
