Front camber kit 3GS
I let a guy at the shop talk me into buying this kit as I was under the impression that it would help with the vibration on my AWD (lowered on coilovers ). It did not, but I also thaught it would avoid any negative camber with my 19" vossen with a +32mm offset, with it lowered the control arm bangs against the underside, my question is with this width and offset do I even need the kit? The help is appreciated
After lowering an AWD, nothing on the market will help with vibrations. What camber kit did you buy? if you bought Vossens, Im guessing its either a 9" or 10.5". You don't need a camber kit to help the 9" +32 fit. If its a 10.5"+32 then I'm unsure. What tire size do you have on there?
I lowered my 06 gs300 awd on tanabe springs nf210, I used the megan racing adjustable upper control arms, no vibrations, no clunking, and it was able to be aligned perfectly. I would recommend trying those. Awd tend to vibrate more the lower you go, maybe try adjusting your coilovers up a bit
Maybe I just got lucky. But I think they help. When you lower the gs it brings the axles in towards the engine. With the adjustable uppers it brings them out, I can only fit two fingers between my fenders and wheels and I have zero vibrations
Thanks for the info, I may have to try this along with the spacers just incase
