brakes hard upon start up, then normal after I start car
Old 03-07-15, 11:49 AM
Tantrix
Tantrix's Avatar
Default brakes hard upon start up, then normal after I start car
I noticed last night that the brake pedal was hard when I tried to start the car...then it softened up after I started the car.
does this mean my booster is starting to go bad ?
it usually feels normal and soft to the tap when I press the pedal and hit the start button.
any thoughts ?
Old 03-07-15, 01:58 PM
Mesca
Mesca's Avatar
Have you been pressing the brakes when the car is off? Happens to me when I have someone press the brakes when the car is off to tighten my lugnuts. Normally shouldn't be a problem unless it keeps happening.
Old 03-07-15, 03:07 PM
jmack2688
jmack2688's Avatar
It keeps happening on mines, this means something is going wrong?
Old 03-07-15, 03:26 PM
xbladex00
xbladex00's Avatar
Should be fairly normal if u press the pedal a number of times. Now if your pedal goes down all the way when you brake you could have seized calipers which i am having the problem right now.... or you need to change your pads, or water is in your brake fluid system.
Old 03-08-15, 01:04 AM
imadesign
imadesign's Avatar
Your brake booster Check valve is failing
There is a hose from the engine intake to the brake booster. This hose is attached to a small one way valve.
Normally if it fails it allows the booster to pull air inside causing what you feel.
Replace that valve and the rubber o-ring and it should be good to go
Old 03-08-15, 03:27 PM
Othic
Othic's Avatar
Its normal to be semi hard when starting because you have no vacuum assist when the engine is not running
Old 03-08-15, 11:14 PM
xbladex00
xbladex00's Avatar
this.... If this is true, after i fix my seized calipers and my pedal is squishy, the this will be my next go to DIY sounds sorta cheap to fix tho...
Old 03-09-15, 09:40 AM
ReLexing
ReLexing's Avatar
Hello,
Do you know where I can purchase this part?
2008 gs350
I'm having the same issue...
Thanks
Old 03-09-15, 11:46 AM
Tantrix
Tantrix's Avatar
are u sure about this diagnosis ? I'm taking it to the dealer today.
Old 03-09-15, 06:52 PM
xms
xms's Avatar
Originally Posted by ReLexing
Hello,
2008 gs350
Thanks
Dealer item only here the part # for check valve 44730 and the o-ring part # 44696
Old 03-10-15, 05:29 PM
Tantrix
Tantrix's Avatar
ok guys had the car checked out at longo lexus in el monte, they took it overnight and said everything was ok.
I feel comfortable taking their word for it. The service advisor Paul and all they other guys seem very knowledgeable with everything.
I gotta say, they have the best customer service ever. I was given a loaner as well. U can't beat lexus service. Mind you my car is a 2007 and it has 108,000 miles.
Old 03-12-15, 08:27 AM
GS350Lexus
GS350Lexus's Avatar
I have this happen once in a while, it seems to be all normal if you asked me.
Old 03-13-15, 02:07 PM
Tantrix
Tantrix's Avatar
Ya looks like a few IS guys also brought this up but there were no safely brake functionality issues.
Old 03-16-15, 02:11 PM
xms
xms's Avatar
I just got my parts in from my dealer new check valve and oring ill report later
Old 03-16-15, 05:32 PM
xms
xms's Avatar
well i installed a new check valve and oring and after 3 hrs of sitting, problem is still there
Quick Reply: brakes hard upon start up, then normal after I start car
