trouble with Vsc/check engine/ and Trac light
Old 12-12-14, 06:26 PM
artybaby2
artybaby2's Avatar
Default trouble with Vsc/check engine/ and Trac light
2006 gs 300. Been driving car around and the 3 lights came on which are vsc, Trac and check engine light all at the same time. Replaced the 2 front O2 sensors but the light keeps coming on and off. When I drive the car the car hesitates to go over 25 mph. Can someone please please help me to find a solution. Thanks
Old 12-12-14, 06:48 PM
Mr Jokster
Mr Jokster's Avatar
Welcome to the Club. You might want to try the 3rd Gen section. Also, try those terms in the search, you'll get quicker answers.
Old 12-12-14, 06:55 PM
Wht95scort
Wht95scort's Avatar
What are the trouble codes? More info would yield better answers.
Old 12-12-14, 07:06 PM
artybaby2
artybaby2's Avatar
I don't have the trouble codes. Where would I be able to obtain these from?
Old 12-12-14, 08:21 PM
Marklopez
Marklopez's Avatar
Obd 2 scanner. Go to an autozone. Or if your state dosent allow it get one online
Old 12-13-14, 12:59 PM
artybaby2
artybaby2's Avatar
So the code is P0037.
Old 12-13-14, 04:44 PM
artybaby2
artybaby2's Avatar
Help please
Old 12-14-14, 12:02 AM
Deadpool88
Deadpool88's Avatar
See above
Ten useless letters
Old 12-15-14, 09:05 AM
FrankT
FrankT's Avatar
You replaced two good sensors.
That code is for bank 1 sensor 2...a heat control curcuit on the rear sensor on cylinders 1,2,3 or bank 1.
You may also have a short in that curcuit.
Old 12-15-14, 02:43 PM
LeTechSpec
LeTechSpec's Avatar
Is there another code? Bank 1 sensor 2 usually means the post cat sensor. Typically, pre cat adjusts the fuel trims and post cats check if the cats are working. Post cats don't typically influence the fuel trim so I don't see how it could have hesitation. Something else is going on here
Old 12-15-14, 09:45 PM
kit cat
kit cat's Avatar
Welcome to ClubLexus.
First and foremost, you are in the section of the forum. You have a 3rd generation GS which has a very different architecture. This is the 2nd generation GS forum. Between these two generation, the engine is completely different.
Also as others have suggested, we will probably be able to help you better (and I suspect more of us will be willing to help) if you could even just do a common google search (e.g. What is Pxxxx Diagnostic Trouble Code (DTC)?" So you could have some very basic fundamental background of the topic at hand; you would be surprised how much more effective communication can be by just remembering hearing some terminology though you may not remember the definition.
Again, we are here to help but would make helping you much more easier if you could post in the correct sub forum and be proactive and at least googling. As a moderator, I have to make sure the forums massive amount of information remains well organized for future reference, therefore, I am moving this thread to the 3GS sub forum. Good luck.
Old 12-22-14, 09:51 AM
artybaby2
artybaby2's Avatar
I changed all 4 sensors and the check engine light vsc and traction control light came on again. Do u know it could be???? Thank u for your help
Old 12-22-14, 10:58 AM
artybaby2
artybaby2's Avatar
I changed all 4 02 sensors reset the code... the next day the lights came on again vsc check engine light and traction control light.... anyone have had the same problem??? I don't know what could be causing the lights to come on??? Please I need help..... thank u all for your time and help...
Old 12-22-14, 11:32 AM
Gotcha350
Gotcha350's Avatar
Instead of just throwing parts at the lights you need to take the car and have the issue properly diagnosed. Could be a wiring issue or another faulty part...(catalytic converter)
200 GS300 is also known for having the carbon build up issue.
Old 12-22-14, 11:49 AM
IXI187IXI
IXI187IXI's Avatar
hmmm those lights usually come on for the gas cap as well but it wouldnt affect driving like your mentioning it
Quick Reply: trouble with Vsc/check engine/ and Trac light
