Low tire warning light / 2008 GS 350
2 weeks ago light came on.......had pressure checked in all 4 tires......1 tire slightly low and light went out.
Yesterday light came back on.
I have been reading some posts on this.
Is there a chance my spare tire could be low and this is causing the light to go off?
Could a sensor be bad and need replaced?
Thoughts / comments / ideas would be appreciated.
Well check the pressure on the tire that was low, then go from there. It could have a small leak. Also Check if your spare tire has a sensor cuz my 07 does not have a sensor, but yours might. Is so check the pressure. If all the pressures are fine then you might have a bad sensor. Good luck.
