any possible way to get led DRL or just HID only?
Old 07-18-14, 07:57 PM
taimysho0
taimysho0's Avatar
Default any possible way to get led DRL or just HID only?
looking around on the forums doesnt seem like its possible to swap out the drl to led since theyre also the high beams. would it just be a simple HID install, and potentially having shorter life span of the HID?
Old 07-18-14, 08:40 PM
SILENTM
SILENTM's Avatar
if you put in leds you will also need to put in the led decoders to make them work correctly, this was the route i went and all is working fine for me
Old 07-18-14, 10:19 PM
taimysho0
taimysho0's Avatar
what are these decoders? do you have a diy i can use for this or is it just plug and play?
Old 07-18-14, 10:22 PM
SILENTM
SILENTM's Avatar
its plug and play look up led decoder on ebay need 9005
Old 07-18-14, 10:25 PM
taimysho0
taimysho0's Avatar
just found this thread but not sure what is the purpose of the decoder? is it so i have the ability to high beam?
https://www.clublexus.com/forums/rx-...d-decoder.html
Old 07-18-14, 11:25 PM
SILENTM
SILENTM's Avatar
yes my hi beam works plus the led wont flicker since drl run at half power
Old 07-28-14, 06:48 PM
taimysho0
taimysho0's Avatar
so i bought the drl leds with the decoder like you mentioned but it looks like the below. what am i supposed to plug into the other socket? when i took out my DRL bulb it was attached to 2 wires, i couldnt remove the bulb. the bulb themselves were part of the wires
do i just connect the two wires to the socket and solder it?
Old 07-28-14, 08:02 PM
taimysho0
taimysho0's Avatar
nvm, figured it out. led and high beam working great!
Old 07-29-14, 06:56 AM
warandcar
warandcar's Avatar
you have LED high beams? i thought once you changed out the bulbs to LED you lose the high beam functionality...
Old 07-30-14, 03:18 PM
ADI$A69
ADI$A69's Avatar
please explain in more detail, I was just about to do this mod.
Old 07-30-14, 05:22 PM
warandcar
warandcar's Avatar
yeah me too…i love the color of the LED's but still want functionality...
Old 07-30-14, 07:12 PM
mr3gs300
mr3gs300's Avatar
which ones did u get and from where?
Old 07-30-14, 08:54 PM
taimysho0
taimysho0's Avatar
i bought these, basically the leds turn on while driving and when i high beam it gets really bright and i can see the reflection on my garage door for example
http://www.ebay.com/itm/171384283664?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Old 07-31-14, 07:36 AM
SILENTM
SILENTM's Avatar
Cree Led are the way to go. mine are similar but have small leds around the out side as well so they really light up the whole housing
Old 07-31-14, 09:52 PM
Mistahoo
Mistahoo's Avatar
2 Pcs 9005 5W CREE HID White LED DRL Fog Light Bulbs with Load Resistor Decoder | eBay
So the decoders allow high beam functionality with LEDs? Looks like I'll be swapping my DRLs soon! Any comparison with the new CREEs vs stock as far as brightness? I like the LED look, but definitely have to pass if it's not as bright as stock.
Quick Reply: any possible way to get led DRL or just HID only?
