Staggered... or not to stagger... that is the question.
Old 06-24-14, 12:06 PM
IXI187IXI
IXI187IXI's Avatar
Originally Posted by Schmexus
Does it really save money? I've never understood that. Your tires are still going to wear out one way or another. If my rear tires wear out first because I can't rotate then I'll buy 2 new rear tires and replace the 2 fronts when they wear out. If you rotate every 5k and your tires wear down perfectly even at the same time you will have to buy 4 new tires.
I just don't see the money savings. Especially if you take into consideration the cost of rotating tires at a shop every 5k miles.
i never understood this either as most tires are directional so you can only swap front to back on the same side of the car. imo not worth the hassle.
Old 06-24-14, 01:09 PM
typrice
typrice's Avatar
Im going with the 45mm set up in the rear!!!!!! YAY!!!! i think my mind is made up.
Old 06-25-14, 10:45 AM
Need4Speed
Former Sponsor
Need4Speed's Avatar
It 'll look Great !
Old 07-10-14, 06:19 PM
Broken2G
Broken2G's Avatar
Originally Posted by Need4Speed
Vossens are a good choice being a premier original authorized dealer for them I would recommend the following
For the GS I would do a staggered setup for the car.
20x9 + 38
20x10.5 + 45
245/30/20
275/30/20
Keep in mind with a square fitments 20x9 will not a give deep concave
it really comes down to what you desire
With this wheel and tire setup, how much does the rims face stick out past the tires side wall?
Old 07-11-14, 12:05 AM
YogiFTLC
YogiFTLC's Avatar
I'll be running pretty much a non staggered setup later on. Same size wheel and tire. We'll see how this goes But then again, I'm the ugly duckling out of the 3gs community. haha.
Old 07-14-14, 08:37 AM
Asav
Asav's Avatar
Check the wheel thread. That's where i got tons of good information from 70-80 pages of various looks with different offsets and tire combos. Then, I hit up rominl for some pointed questions that he was happy to answer. Do your homework first so you get a good idea of what you want to accomplish.
Old 07-14-14, 06:06 PM
Brotha500
Brotha500's Avatar
since soneone brought this post back up how bout some pics of the setup op!!???
Old 07-14-14, 09:12 PM
Mistahoo
Mistahoo's Avatar
Staggered look is amazing!
Old 07-14-14, 09:20 PM
metaleckz
metaleckz's Avatar
How about 10.5 front and rear
Old 07-21-14, 11:55 PM
Mesca
Mesca's Avatar
Do not recommend 10.5 in the front unless you plan on severe modifications.
Old 07-24-14, 02:22 PM
j3g
j3g's Avatar
so 10.5 in rear...and no rubbing fenders? this thread has convinced me to go staggered.
Old 07-24-14, 07:16 PM
snkepit
snkepit's Avatar
I second that
Old 07-24-14, 07:35 PM
Schmexus
Schmexus's Avatar
Totally depends on the offset and tires.
Old 10-07-15, 03:04 PM
wickedtaco
wickedtaco's Avatar
Schmexus, if running a square setup what would be the ideal offset and tire size for the front to prevent severe modifications?
Sevn86
10-02-15 04:22 PM
jkonquer
Suspension and Brakes
10-22-14 08:02 AM
ZaxF
05-29-14 06:06 PM
Stormforge
10-07-08 08:07 PM
ifilrx
Wheels, Tires & Brakes Forum
35
10-09-05 09:15 AM
Quick Reply: Staggered... or not to stagger... that is the question.
