Loss of gas power after buying gas
Old 10-04-13, 11:08 PM
Cindyrella
Cindyrella's Avatar
Default Loss of gas power after buying gas
Bought gas for 2007 GS 350 and immediately had a loss of gas power. I was not able to travel over 40 miles per hour. A few times had to pull over going up a hills due to loss of gas power.
I ran codes at Auto Zone and received P0158, P0606, P0300, P0352,P0303.
I will try a new gas cap, assuming I did not get bad gas. I put fluid into the gas that helps if I received bad gas but it was no help. The Check engine light is on, VSC, traction control or anti skid and also the "!" is on as well.
Any ideas before I have to take to the dealer or an Auto Shop.
Thank you in advance and I am sorry if this has already been posted but I am new to this site.
Old 10-05-13, 12:43 AM
gc86
gc86's Avatar
did you fill the car up with diesel or 87 octane?
Old 10-05-13, 07:21 AM
Polymathic
Polymathic's Avatar
Angry Same problem.....help!
FREAKIN DUDE AT THE GAS STATION COMPLETELY LEFT MY GAS CAP OFF AFTER PUMPING '87' INTO MY TANK ...NOW EVEN AFTER REPLACING CAP I HAVE THE SAME LIGHTS ON FOR A WEEK NOW. HOW DO I AVOID GOING TO THE DEALERSHIP AND PAYING AN ARM N A LEG TO JUST REMOVE THESE WARNING LIGHTS? WILL A BATTERY DISCONNECT WORK?
Old 10-05-13, 07:50 AM
worker
worker's Avatar
^ usually I don't recommend clearing the code. Best have dealer check it out.
if you still really want to clear the code, which will clear the check engine light too... you can borrow Autozone code reader and use it to clear the code.
Old 10-05-13, 07:54 AM
Polymathic
Polymathic's Avatar
"^ usually I don't recommend clearing the code. Best have dealer check it out." <<<< EVEN IF ITS OBVIOUSLY CAUSED BY THE "GAS CAP" ISSUE?
Old 10-05-13, 08:39 AM
XxGoKoUxX
XxGoKoUxX's Avatar
What gasoline grade did you use? Make sure you used what you used because it is on your receipt slip (I keep all my receipts for end of the year taxes).
This doesn't look like anything gas-cap related IMO. You're having tons of misfire codes. Could be you picked up bad gas or your car has WATER in the gas. Might want to try the gas cap remedy first, then take it to a mechanic.
FYI: During my gas cap failure, I had no such problems. Car drove perfectly fine, it was just a CEL and TCS off.....I think that's about it. Wish you the best of luck OP!
No need for caps locks in your convos .
If it's obviously gas cap issue, go to autozone and just have them reset the codes. You're probably going there to pick up a new gas cap anyways, right?
Old 10-05-13, 08:44 AM
ibidu1
ibidu1's Avatar
Yup sounds like he put diesel in there, I would remove the fuel out of the tank.
Old 10-05-13, 09:34 AM
YaMomma
YaMomma's Avatar
Sounds like diesel to me too, 87 wouldn't cause all of the problems you are experiencing.
Old 10-07-13, 07:17 PM
mjlexus
mjlexus's Avatar
In most NY gas stations the diesel pump nozzle cannot fit into a gas tank receptacle...not sure if that is the same elsewhere.
Old 10-07-13, 08:18 PM
XxGoKoUxX
XxGoKoUxX's Avatar
I didn't know that, very interesting as that is not the case for FL. In FL all the nozzles are universal
Old 10-08-13, 07:03 AM
BinaryJay
BinaryJay's Avatar
Did you happen to fill up when there was a tanker there delivering gas to the station? I will never fill up gas when I see a tanker... when they deliver the fuel, it stirs up all of the detritus that usually just settles harmlessly at the bottom of the tanks underground - sand, scum, water.
Unless it's just a fluke then I think you got a tank with too much water.
Old 10-08-13, 09:09 AM
XxGoKoUxX
XxGoKoUxX's Avatar
I'm definitely feeling the same way Jay.... especially with the fact that the car still RUNS..... If it were diesel, the car would have died after about 30s-1min time on the road.
Old 10-08-13, 09:01 PM
chuckGS350
chuckGS350's Avatar
Same in Mass.
2012ISF
IS F (2008-2014)
25
09-22-12 05:41 PM
OCLEX03
07-29-10 09:37 PM
ROBGS300
GS - 1st Gen (1993-1997)
01-07-09 05:35 PM
soulsoarer
06-25-06 05:56 AM
caymandive
06-10-06 02:30 PM
Quick Reply: Loss of gas power after buying gas
