Can the 2006 tail light be opened?
Old 09-17-13, 07:40 PM
mjlexus
mjlexus's Avatar
Question Can the 2006 tail light be opened?
Hi All,
One of the lens in the right outer tail light of my 06 GS300 has become dislodged? Is it possible to open the tail light to get to the lens?
Thank you
Old 09-18-13, 01:34 AM
XxGoKoUxX
XxGoKoUxX's Avatar
Not many people have done this... Can you snap a picture of what's going on?
If it is what I think it is, it may be glued... And you just have to remove the taillight, put it in an oven at x-x-x degrees (refer to headlight removal for a guide), and let the glue melt to pull the taillight apart.
GL OP!
Old 09-18-13, 02:51 AM
IXI187IXI
IXI187IXI's Avatar
anything can be opened
in all seriousness though, id just buy another light. they arent that expensive anymore and imo id rather just do that then waste the time
Old 09-18-13, 05:40 AM
SLOW4DR
SLOW4DR's Avatar
^Lol. I'm curious what is loose.
Old 09-18-13, 06:24 AM
worker
worker's Avatar
worse case cut it out and glue it back in.
if there is a will, there is a way. I have turn to the hammer a few times, usually end up buying new one. LOL
Old 09-18-13, 06:35 AM
BinaryJay
BinaryJay's Avatar
Don't know what you're talking about.
Old 09-18-13, 07:48 AM
ibidu1
ibidu1's Avatar
Guys who open up headlights use and over at a really low temp for like 5min it usually softens the sealing material
Old 09-20-13, 05:48 AM
mjlexus
mjlexus's Avatar
Default picture
I am having a problem uploading the image. It is a strange problem. Thanks for the suggestions....including the hammer....should be a lexus hammer though
Old 09-20-13, 07:31 AM
XxGoKoUxX
XxGoKoUxX's Avatar
hrmm..... www.tinypic.com
I use that for temporary photo storage.... Also, resize your images if they're too big.... if they're too big sometimes they don't work. If the size of the photo is HUGE, then your photo will take a lot longer to process through during the upload (unless of course you know all this, then my bad lol).
Old 09-20-13, 04:23 PM
mjlexus
mjlexus's Avatar
Default Picture of dislodged lens
This might not be the best picture but it should give an idea. Haven't seen anyone with this problem.
Old 09-21-13, 09:03 AM
XxGoKoUxX
XxGoKoUxX's Avatar
how the f..... did that happen? lol!
Yeah..... remove your taillight and see if there are any further screws holding it in
If not, it's oven time for removal
Old 09-21-13, 03:46 PM
mjlexus
mjlexus's Avatar
Not sure how it happened...It has small tabs at the end that holds it in place but they might have snapped. I probably will go for a new one.
Old 09-21-13, 05:30 PM
XxGoKoUxX
XxGoKoUxX's Avatar
lol.... Definitely do a write-up for future owners! If you get a new one, you should definitely experiment with that one and open it up!
Oh how I wish it was your driver side I actually only need the outer lens and would have loved to take it off ur hands.
CoOl21
SC- 1st Gen (1992-2000)
11-21-16 05:34 PM
deestyle28
02-16-15 11:58 AM
sebtown
07-31-12 06:46 PM
#1gs300
10-10-06 06:59 PM
thebanez
09-03-05 02:20 PM
Quick Reply: Can the 2006 tail light be opened?
