Need help on trunk setup..
Old 07-26-13, 11:34 PM
endlesslex
endlesslex's Avatar
Default Need help on trunk setup..
im trying to save room in the trunk, but still want sounds and keep the bags set up.. any ideas and pic?.. thinking about going with redwood and polish aluminum LINES...
Attached Thumbnails Need help on trunk setup..-heknd.jpg   Need help on trunk setup..-womflf.jpg   Need help on trunk setup..-plfnnfvde.jpg   Need help on trunk setup..-jdlde.jpg
Old 07-27-13, 08:16 AM
XxGoKoUxX
XxGoKoUxX's Avatar
I'd close up that middle section (if that first pic is what ur car is like), with the cover, make it look OEM.... and glass the two pockets on the left and right side with a nice box on each side..... Use a 13TW5 on each side since airspace is not your friend.
That's if you like as close an OEM setup as possible.
I took my two compressors and my tank and put it on a board already, with a bracket from home depot (bracket was like quarter-in thick so it holds up well), and now I'm waiting to glass the two sides when I have time .
GL either way!
Old 07-28-13, 03:36 PM
swtjlsy
swtjlsy's Avatar
either one of those dorbitz Designs is not saving space get a smaller tank and put it on the side have one 12 ported thought the factory sub hole or ski pass. I could design trunks all day long of what I do that for a living lol
Old 07-28-13, 08:52 PM
XxGoKoUxX
XxGoKoUxX's Avatar
you could also do a 4th order bandpass through the ski pass, it'll be loud as heck too!
I didn't think of that Mike.... Now u make me wanna change my setup AGAIN.....
Old 07-29-13, 04:27 PM
swtjlsy
swtjlsy's Avatar
[QUOTE=XxGoKoUxX;8062429]you could also do a 4th order bandpass through the ski pass, it'll be loud as heck too!
I didn't think of that Mike.... Now u make me wanna change my setup AGAIN.....[/QUOTE
I did mine like this just want it to be loud inside the car instead of traveling outside. port though the rear deck if you want it to travel
Old 07-29-13, 04:29 PM
swtjlsy
swtjlsy's Avatar
I think I would also do dual exo mounts on each side of the trunk to make it look right then cover the spare in peli and light it up
Old 07-29-13, 10:12 PM
XxGoKoUxX
XxGoKoUxX's Avatar
why can't you be around when I wanna do a glass setup in the rear
KOKISF
IS F (2008-2014)
14
09-19-14 06:35 PM
Nova
SC- 1st Gen (1992-2000)
05-06-12 09:39 AM
Timo5701
48
04-10-09 05:39 PM
RSTSpeed
01-26-04 05:24 AM
engin_ear
05-12-02 11:51 AM
Quick Reply: Need help on trunk setup..
