Akebono brake pads
Old 05-31-13, 02:18 PM
Ab423
Ab423's Avatar
Default Akebono brake pads
Ok I'm about to change all four pads and went with Akebono proact pads and they include the shims. My question is should i use the oem shims since its four of them or can I just use the outer shim and leave the one that came on the pads if ist even possible or just only use the shims provided with the Akebono brake pads
Old 05-31-13, 02:36 PM
GS350Lexus
GS350Lexus's Avatar
When I used akebono brake pads, I left the one's it came with. But in that process I lost my OEM shims which are not cheap to acquire after. So i would suggest to leave the OEM shims.
Old 05-31-13, 09:46 PM
ibidu1
ibidu1's Avatar
You cant run the aftermarket pads with the oem shims.
Old 06-01-13, 04:22 AM
Ab423
Ab423's Avatar
Is that the aftermarket pad only come with one shim and oem has 2 for each pad to reduce the chance of noises ... So your saying I should be fine with just that one shim on the Akebono pads ?
Old 06-01-13, 05:48 AM
Diesel350
Diesel350's Avatar
I installed my Akebono pads without putting the OEM shims on them and I have had no noises whatsoever. When you install them just make sure to add anti-squeal compound to the back of the pads.
Old 06-01-13, 05:37 PM
Whitena
Whitena's Avatar
Any feed backs on Akebono pads, I'll be changing my front pads pretty soon.
Old 06-01-13, 08:16 PM
Diesel350
Diesel350's Avatar
These are very good pads. Very low dust compared to OEM's
Old 06-03-13, 08:16 AM
MCCR
MCCR's Avatar
these are the pads i'll be using up front soon. did you go with stock rotors?
Old 06-03-13, 08:20 AM
IXI187IXI
IXI187IXI's Avatar
i replaced my rears with those after my oem rear pads fell off the backing. thankfully it was at the body shop at the time or i could of had a real issue.
Old 06-03-13, 09:32 AM
GS350Lexus
GS350Lexus's Avatar
What did you do to those pads that they fell off the backing?
Old 06-03-13, 10:12 AM
IXI187IXI
IXI187IXI's Avatar
normal driving. they still had a good bit of life left on them too. they just fell off i guess ive never had that happen before. i was pleased though when i switched to the akebono pads.
Old 06-03-13, 11:27 AM
Diesel350
Diesel350's Avatar
I upgraded my rotors to Centric premiums since my stock rotors were pretty much gone.
Old 06-03-13, 09:13 PM
Macboi
Macboi's Avatar
Would changing to these have any negative to it like squealing or anything different
Old 06-04-13, 10:01 PM
illini19
illini19's Avatar
2008 GS350 AWD - Going on either this weekend or next. Just need to find the time. The pin and bushings are for my driver side rear caliper that is seized. Just in case I needed a new one if the old one is in too bad of shape.
Old 06-07-13, 09:26 AM
phat32
phat32's Avatar
I just purchased the same setup with the akebono pads and centric premium rotors for my 06 GS 300 AWD. i did some product reviews on these individually but nothing together... everything i read was positive stuff, once i put mine on this coming tuesday ill advise on what i think.
Quick Reply: Akebono brake pads
