Trunk Won't Open (Non-valet switch problem)
Old 09-10-15, 09:51 AM
Hasman69
Hasman69's Avatar
Update - Went to the Lexus dealership, they did the initial diagonosis as something wrong with the electrical, kept the car for another hour and then said they need to order some parts worth $1200 but since its under warranty so I DONT have to pay anything, its all covered.
Yay for Lexus.
Old 09-16-15, 12:04 PM
artboy
7th Gear
artboy's Avatar
Post I tried all these things. No go.
Originally Posted by maddenmg
Remove HCU fuse under hood left side. Start engine stop engine. Replace HCU fuse and trunk lid. Will now open.
Dealer charged me $ 1200 to replace some electro hub. That hurt my wallet.
Im going to have to find a good indie shop here in LA.
Old 10-17-15, 09:04 AM
soilape
soilape's Avatar
For me it was the valet button. But thanks anyway. These advice led me to the right tracks.
Old 10-17-15, 10:10 PM
tatumjonj
tatumjonj's Avatar
I just wanted to actually join the forums and say thank you. The ECU-B fuse trick didn't work but removing the negative battery terminal for 15 seconds fixed my trunk. Thank you so much for the help.
Old 03-08-16, 12:59 PM
2009gs
2009gs's Avatar
I had the same problem. One morning the dash said the Trunk was open and neither the interior button, the key fob button, or the exterior trunk release button would do anything to open the trunk. The car thought the trunk was already open.
The only method to open the trunk was manually with the hard-key.
I called the dealer and even though they had never heard of this problem before (yeah right!), they said to bring it in and they could figure out what was wrong.
I searched and found this thread instead, and tried all the tricks outlined in here, including pulling the ecu-b fuse. That didn't work. Finally I opted to try pulling the negative battery cable and that did the job.
Thanks everyone - good job helping the community and saving people $$.
Old 03-09-16, 03:49 PM
hiih8er
hiih8er's Avatar
I'm glad somebody revived this thread. Yesterday I noticed the trunk on mine wouldn't open. I'll give this a try.
Old 08-31-16, 08:57 AM
singh7
singh7's Avatar
Same problem with my gs 350 2007
tried removing the ecu b fuse it dint work for me
then disconnected the negative terminal of the battery for around 20 mins and when I opened the trunk it did open huuurrraayyy
but sadly it opened only once 😭😭😭😭 and the same problem again
Old 08-31-16, 11:52 AM
singh7
singh7's Avatar
I repeated the same process again and this time also was able to open the trunk only once
Old 10-15-16, 07:33 AM
deton8
deton8's Avatar
Just had this happen to me. I was all set to disconnect the battery when I figured I'd try the valet button first... That did the trick.
Old 10-16-16, 12:58 PM
allroad360
allroad360's Avatar
Originally Posted by Conceptvip
disconnect the battery for 15 seconds and should fix it. There is a tsib to prevent this happening, it is to replace the drivers junction block.
This worked, good tip.
Old 02-20-17, 07:34 AM
Midasking
Midasking's Avatar
Default Worked!
Be sure to turn your vehicle completely off-OFF (close all doors & hit alarm button twice), before re-installing ECU-B fuse. First time I tried the car wasn't all the way off - and it didn't work!
Forget disconnecting battery, too many complications, Find the ECU-B Fuse in the Fuse box under the hood to the left, remove this fuse, start the car, stop the car, replace the fuse, restart the car and the trunk lid will OPEN. Worked for me today just fine on my GS350 same intent as battery without the other consequences, and your battery will stay just like it was...
Old 08-25-17, 06:04 PM
sanguine
sanguine's Avatar
Default Thank you for this thread
This thread helped me resolve the issue I faced this morning with my '07 GS350. I hit a speed bump, then my trunk popped open, I ran out and closed the trunk and drove away, minutes later my dash said the trunk is still open. I went home and was only able to open the trunk manually. I disconnected the battery for a couple minutes and reconnected, everything works now. Remember to reset your windows as well!
Old 11-08-17, 08:38 PM
johnnyrock
johnnyrock's Avatar
Hi Singh7,
I just PM you. tried to fix the trunk problem of my GS300 and found your post. i have exact issue as yours, that trunk only works once. have you solved the problem already? Thank you!
Old 06-07-18, 11:05 AM
majorlee
majorlee's Avatar
just gotta 2006 GS450h, seriously fun, just had first issue pop up and its this so will give these two ideas a go thanks
Old 06-07-18, 06:08 PM
guzzy92fs
guzzy92fs's Avatar
Happened tth same to me last week, did as the following TSB and works like new again, pretty much reconnecting junction box connectors.
File Type: pdf
Quick Reply: Trunk Won't Open (Non-valet switch problem)
