How To Replace Lexus GS300 Headlight Bulb
Old 01-25-13, 08:17 AM
LexiLex
LexiLex's Avatar
Default How To Replace Lexus GS300 Headlight Bulb
How do I replace my gs300 headlight bulb with out removing the bumber??? Or is that possible?
Old 01-25-13, 08:25 AM
Cartune
Cartune's Avatar
Ne need to remove bumper. Open your hood, twist the bulb door/cover(not sure what's the right term) and replace the bulb
Didn't realize this was on 3rd gen, thought it was 2nd gen, I could be wrong but should be the same
Old 01-25-13, 08:28 AM
LexiLex
LexiLex's Avatar
Okay thanks! I'll se if I can find a picture of that so I'll know what I'm looking for. Really appreciate it
Old 01-25-13, 11:04 AM
jre002
jre002's Avatar
It's very easy on both sides. 3 minutes each bulb.
Old 01-26-13, 06:21 AM
Chaos236
Chaos236's Avatar
Thank you,I'm doing it this weekend also.
Old 02-12-13, 03:48 PM
fventura03
fventura03's Avatar
1. pull out the clear plastic cover by rotating it.
2. unlock the metal cover that has the plug for the bulb, there is some arrows on it showing which way to lock it, do it the opposite to unlock it and pull it out.
3. there is a little metal thing holding the bulb into the headlight assembly, unclip these and the bulbs will come out.
on drivers side I had to remove the windshield washer spout since I have big hands, just needed a 10mm.
took about 20mins for my first time and not knowing what I was doing...
Old 02-12-13, 05:42 PM
bigblack06
bigblack06's Avatar
Here you go.
https://www.clublexus.com/forums/gs-...fter-pics.html
cobraBLACK (11-05-21)
RAMBLER2
05-12-18 01:48 PM
melbitoast
IS F (2008-2014)
02-22-17 10:40 AM
lserlohn
RX - 1st Gen (1999-2003)
11-11-11 06:25 PM
TORTOISE
01-05-09 11:10 PM
933005spd
SC- 1st Gen (1992-2000)
10-05-02 08:16 PM
Quick Reply: How To Replace Lexus GS300 Headlight Bulb
