Coolant Change?
Old 07-24-12, 11:33 PM
crombie92
crombie92's Avatar
Default Coolant Change?
Has anybody done a coolant change? Where exactly is the open valve? And is red the only color that should really be used? Thanks.
Old 07-25-12, 04:27 AM
burny
burny's Avatar
I believe it is bottom of radiator on drivers side. White draincock. Use Toyota red. You can get it mixed 50-50 or get full strength and mix it with distilled water. After you get about a gallon in there, cut the car on and turn heater on high and top off as necessary. Clean and refill the overflow jug too.
joeyfett
02-12-14 06:46 AM
wvuguy
RX - 1st Gen (1999-2003)
14
04-17-10 09:05 PM
arodriguez
Maintenance
01-09-09 03:52 PM
rtk7
01-12-08 02:20 AM
2002RX300
01-22-07 08:51 AM
Quick Reply: Coolant Change?
