My front is 20x9.5 +40 offset but I add 15mm spacer with 225/35 tire. Rear is 20x10.5 +20 offset with 245/35 tire. You definitely need to shave the front, roll the rear and -2 camber should be clear for your setting.
You definitely need to roll/shave fenders, tires must be stretched. You can't get away from those two. I recommend 225/35 up front, 245/35 or 255/30 for the rear.
