FML i cut the holes for my UCA!!! No going back now...
So we re-installed my air ride after a long winter. I was talking to the guy who installed it and told him the idea, one thing led to another and fml we did it. I've been thinking about doing it since i put in the air ride.
So here is what we did.
Judging by the dents underneath we drilled a pilot hole.
Then we used a 2.5" hole saw and cut it down from the top.
The hole cut very clean, then we used a file cut clean it up
We put an industrial tape on from the top and sprayed uncoating on it. I will probably have a body shop make me covers for them
Here's the AFTER, got about 1/2" of extra drop
Here is almost the same picture BEFORE without the cut
This mod will not effect the bodies integrity or the suspension. You would have to have cut near the welds for that to happen..
I forgot to mention this part, anyone's who is really low knows how bad the car can bottom out, it's crazy. This should help...
hey i cant really tell through the pictures on the height difference but was it worth it? Do the lips tuck or do you have better pictures of the slammed height? thanks in advance bro.. thinking of doing it myself.. I have that tool to cut out holes.. def want to try it out..
your upper control arm will sit touching your top inner fender aired out. Or it with just bottom out hard. Cutting then out give you a little extra space...
