GS transmission problems?
Old 09-17-12, 06:03 PM
Boron
Boron's Avatar
Originally Posted by yadadaHan
i think my 06' gs300's tranny is going out. check vsc light came on and car won't shift pass 3rd. tried a transmission fluid flush and same problem came back within 30 miles. has anybody else had this problem? it only has 94,288 miles!
Does it not even shift using S mode?
Might be worth seeing if you can get the transmission out and the torque converter removed.
At least that way, you''ll be able to get the full amount of old oil out, and refilled with fresh oil.
There's another thread(s) running here where a member had an issue that a change (tranny in situ, so not full fluid amount) of fluid seems to have cured it, and in it or another thread, talk about possibly being one or two cheaper parts needing replaced rather than a full transmission swapout as would be the case when you take it to a dealership.
It/they were recent-ish threads, so have a search or look deeper than page 1, and you'll find it/them easily enough.
Hopefully there's help and advice in it/those which helps get you sorted.
Old 06-19-13, 10:14 AM
Bilal01430
Bilal01430's Avatar
2001 gs430 with 180k check engine light on for Solenoid should i replace it or rebuild the whole tranny?
Old 06-19-13, 11:56 AM
lex-ative
lex-ative's Avatar
06 GS430 reaching 150K miles now... Bought it used with 136K miles..... looked at service records and see no tranny flush or replacement, so I assume still original tranny with original World Standard fluid sloshing in it.... still shifts fine.....(knocking... no...destroying wood.....)
Old 06-19-13, 12:58 PM
worker
worker's Avatar
GS430, alternator problem and change the gas cap too. No other issues.. well hit a pot hole once and blew my tire if that count. LOL
*knock on carpet*
Old 08-06-13, 01:30 PM
sirblinks
sirblinks's Avatar
Good question, I have this issue as well, some input would be highly appreciated!
Old 02-12-14, 01:05 PM
Gs350Lola
Gs350Lola's Avatar
156k 2007 gs350 no power reversing check vsc light on. Most likely need a new tranny.... sigh....
Old 02-12-14, 01:36 PM
tunedis95
tunedis95's Avatar
2006, GS430 6speed with 128k miles. Shifts like a dream, well my dreams....couple more gears would be even smoother. Lol
Old 02-12-14, 03:14 PM
EyeKutr
EyeKutr's Avatar
old thread but fwiw 91k on 06gs300, shifts great. I plan to do the tranny service at the next oil change
Old 02-12-14, 05:57 PM
korlexus
korlexus's Avatar
07 GS350 with little over 80,000miles, never had a transmission problem.
Only weird noise from the brake.
*I don't own it anymore though
Old 02-17-14, 11:05 PM
GS430GS430
GS430GS430's Avatar
06 GS430 with 162K miles, shifts smooth. Did a transmission fluid exchange with 10qt of Toyota WS fluid last summer.
Old 02-17-14, 11:08 PM
GS430GS430
GS430GS430's Avatar
Check to see if you have enough fluid.
Old 02-18-14, 07:09 PM
sonnyhood
sonnyhood's Avatar
GS450h - 182,000 kms no gearbox problems with the CVT, i have elected to have the oil service done and changed which is $250 at lexus, pretty happy with that. Done in coming weeks
Old 02-20-14, 03:43 PM
sgvlex
sgvlex's Avatar
87k 2007 gs350, everything is good so far, just got a recent recal done for the camshaft though...
Old 02-24-14, 08:33 AM
SinisterGS
SinisterGS's Avatar
06 GS3 114k No issues knock on wood, but going in for the misfire recall next week.
Old 02-26-14, 01:29 AM
kenv
kenv's Avatar
questions: who did the service? and How Much? I live in San Diego and use Lexus of Escondido.
Quick Reply: GS transmission problems?
