2006 gs 300 ticking noise from engine?
Old 08-06-11, 09:12 AM
mikegs2006
Registered User
mikegs2006's Avatar
Default 2006 gs 300 ticking noise from engine?
ticking noise from engine?is that normal? not that load... but it always did since i had it,, its like almost a diesel ..not that much but almost
Old 08-06-11, 09:20 AM
gridlock13
gridlock13's Avatar
that's the sound of the direct injection system. totally normal.
Old 08-06-11, 09:22 AM
mikegs2006
Registered User
mikegs2006's Avatar
oh ya ? no cure?
Old 08-06-11, 09:28 AM
gridlock13
gridlock13's Avatar
a member here posted that some cover in the LS460 engine works on GS350s to muffle the noise a bit. try the search tool. i'm pretty sure the cover doesn't work on the GS300s though.
Old 08-06-11, 11:13 AM
L3XOTIC
L3XOTIC's Avatar
Its normal, annoying at times but normal. Some cars are even louder, like its breaking.
Old 08-08-11, 08:23 PM
jgr4444
jgr4444's Avatar
ever heard a 1999 civic si "honda-tick" you'll think your ticking noise is nothing after you hear those valves tick.
P.S. I know its not our valves ticking i just was using the reference to relate the sounds.
Old 08-08-11, 09:39 PM
mikegs2006
Registered User
mikegs2006's Avatar
lol i just have to make sure the a/c works so i keep the windows closed!!
Old 08-11-11, 03:29 PM
InvisibleM
InvisibleM's Avatar
funny i hardly noticed it before i saw this post... now i hear it all the time when im out of my car when its running
Old 08-11-11, 06:09 PM
lkapimp216
lkapimp216's Avatar
Get exhaust and turn the sub woofer up, if that doesn t work find a chick that doesn t shut the hell up and marry her!!!
Old 08-13-11, 07:20 AM
R.DUB
R.DUB's Avatar
it's normal and you'll get used to it. High pressure fuel injectors make your valves sound like the ticking. if you keep the throttle open, you're exhaust will drown it out!
Old 08-13-11, 09:17 AM
L3XOTIC
L3XOTIC's Avatar
Audi A4 usually is very loud ticking as well. Almost to the point where its embarassing.
Old 08-13-11, 09:26 AM
maximus001
maximus001's Avatar
Really glad you covered this 'cause I was a bit concerned too. Nice to know it's normal.
Old 08-13-11, 12:00 PM
R.DUB
R.DUB's Avatar
Yeah, when I test drove my GS two years ago, I pulled over to inspect the car and heard it. it was so bad I called the L dealer's service dept and the advisor explained it to me and put this issue to rest. I would recommend checking your VIN to see if you need to have the valve springs replaced under the recall a year or so ago... if you search the forums you'll see some good info on this topic. I had mine replaced (for free) and the car runs great!
Old 01-12-12, 07:43 AM
SlvrBulit
SlvrBulit's Avatar
Can you post the link? I wasnt able to find it.
caddyowner
07-03-18 06:27 AM
skydash
05-16-17 09:06 PM
drstrangel
11-08-09 02:27 PM
klex
07-08-07 03:11 PM
Tlai000
03-31-06 06:36 AM
Quick Reply: 2006 gs 300 ticking noise from engine?
