Stop Wind Deflector From Vibrating
Old 08-20-10, 09:00 PM
bigblack06
bigblack06's Avatar
Post Stop Wind Deflector From Vibrating
I believe someone had posted, trying to fix the sunroof wind deflector from vibrating with bass, I found an easy fix using that sticky velcro felt fasteners (which I picked up at home depot for about $6 for 5' piece) to the wind deflector to stop the contact between the metal vibrating against the sunroof. Will post pictures of what it looks like once installed and how it goes. credit goes to whoever was asking about this.
Old 08-21-10, 05:13 AM
bigblack06
bigblack06's Avatar
Here are the pics as promised if anyone is actually lookingat this!
Attached Thumbnails Stop Wind Deflector From Vibrating-photo.jpg   Stop Wind Deflector From Vibrating-new-image.jpg   Stop Wind Deflector From Vibrating-new-image-2.jpg   Stop Wind Deflector From Vibrating-velcro.jpg
Old 08-21-10, 06:49 AM
*Batman*
*Batman*'s Avatar
How well does it work? What did the original vibration sound like?
I hear a thump sound coming from roof when I hit a bump in the road but I don't know if that is the same thing.
Old 08-21-10, 08:41 AM
worker
worker's Avatar
those pics so close I am not sure what I'm looking at. Is this piece get pull down when the sunroof close? I always want to find out where it hit and just stick it there.
Old 08-21-10, 08:15 PM
bigblack06
bigblack06's Avatar
The sound was mostly like to milk jugs banging together it was basically the metl vibrating against the top half of the sunroof, and that thump also used to happen to me when going over big potholes. tried it today and it works perfectly.
Old 08-21-10, 08:18 PM
bigblack06
bigblack06's Avatar
yeah its right in the middle part of the wind deflector, if you were to touch the wind deflector when the sunroof was closed you could actually feel where it hits the metal. I will try to post some better pics from a distance.
Old 08-21-10, 10:49 PM
worker
worker's Avatar
^ thanks.
I have white Velcro.. guess I now I need a black one.
Old 08-22-10, 05:33 AM
bigblack06
bigblack06's Avatar
Hopefully this pics are a little better!
Attached Thumbnails Stop Wind Deflector From Vibrating-photo-2.jpg   Stop Wind Deflector From Vibrating-photo.jpg
Old 08-22-10, 08:11 AM
BinaryJay
BinaryJay's Avatar
I'm not sure if I've ever heard this noise on mine but thanks for posting just in case I ever do.
Old 08-22-10, 10:15 AM
worker
worker's Avatar
I can hear mine when I drive above 40mph and especially highway speed.
bigblack06, thanks. Does it completely stop the noise? I'll try it out.
Old 08-22-10, 02:57 PM
bigblack06
bigblack06's Avatar
[/QUOTE]bigblack06, thanks. Does it completely stop the noise? I'll try it out.
yeah it works perfectly there is no rubbing against the metal as before.
It moslty quite in the cabin aside from the creaks and rattles from the dashboard.
Old 08-23-10, 10:16 AM
worker
worker's Avatar
is high heat an issue with Velcro adhesive?
Old 08-23-10, 03:58 PM
bigblack06
bigblack06's Avatar
nope it should be perfectly fine as long as your not gonna keep it directly in sunlight for a week straight. just apply and give the adhesive some time to stick, but it really sould be fine, I have had my sunroof open and the sunlight has been beating on it, and has not flown off.
Old 08-23-10, 06:04 PM
worker
worker's Avatar
Oh I know it won't flown off, I just afraid the adhesive melt and create a mess up there.
If I drive high speed and press my hand on this plate, it should stop the vibration while my hand is press right? I want to make sure I am fixing the correct thing.
Old 08-24-10, 06:40 AM
bigblack06
bigblack06's Avatar
yeah if you pushed your hand down on it, it would stop the vibration.
Quick Reply: Stop Wind Deflector From Vibrating
