DIY: remove bumper, Replacing FOGS, DRL, REVERSE, HIGHBEAMS, and SIGNALS in LED
Old 08-31-11, 05:25 PM
  #31
BAUSauto
Former Sponsor
BAUSauto's Avatar
looking good!!!!
Old 08-31-11, 07:35 PM
  #32
rj12
rj12's Avatar
Originally Posted by gridlock13
where are u trying to put these in?
I'm trying to use them as my reverse lights
Old 09-01-11, 04:29 AM
  #33
gridlock13
gridlock13's Avatar
i thought maybe u bought the wrong part but it's right. you just need to use a little force. be careful though. i sorta detached the LED part from the base when i was installing one of my turn signals. had to use gorilla glue and tape to keep it together.
Old 09-01-11, 09:47 AM
  #34
rj12
rj12's Avatar
thanks. got it after trying a couple more times. didn't want to break the thing. a little bluer than i wanted but it works since i had a bulb that went out
Old 09-01-11, 12:08 PM
  #35
rj12
rj12's Avatar
Just had a question on the drl light. I ordered the 9006 but this is actually the only thread for which I've seen it posted as 9006. Most other threads are the 9005. Also in this post is the bulb the high beam light that I would be replacing the 9006 with. I got the city light in which was the light that is on with the headlights at night but noticed inthe day it's still the yellow orig light
Old 09-01-11, 03:29 PM
  #36
gridlock13
gridlock13's Avatar
the DRL bulb and high beam bulb are the same thing, just running at a lower wattage when operating as a DRL
Old 09-25-11, 01:39 AM
  #37
gojeezy123
gojeezy123's Avatar
very helpful post! thanks!
Old 02-21-12, 01:50 AM
  #38
uptownboi
uptownboi's Avatar
Great write up!!! i did my trunk and reverse lights ... and i always wanted LED blinkers... but v-led had been out of stock for the 4led flasher that keeps the lock confirmation (i heard it being called the "new CF18" or CF19).... but i couldn't find it anywhere else.... does anyone know where else i can order it?
Old 05-22-12, 05:26 AM
  #39
tucker21
tucker21's Avatar
i'm going to replace all my exterior lights and sourcing them from v-led sight but my one question is whats the difference between the 360, flank, and forward lights?
am i correct in assuming the 360 leds are going to be best for the parking lights and the reverse lights?
for the fogs i'm thinking blue 9006 and for the low beams phillips 600K HID.
also prolly swap out the reverse lights and then upgrade the LED tail lights.
any suggestions for the best looking LED tail lights?
cheers.
Old 05-22-12, 08:17 PM
  #40
Lex Luga
Lex Luga's Avatar
I never heard of replacing the oem red tail lights. Those things are so bright already, kind of no point.
Old 06-13-13, 09:44 AM
  #41
DCQUEEN07
DCQUEEN07's Avatar
Does anyone know about the clips on the front bumper... if they break are they hard to replace...?
Old 09-17-15, 03:04 PM
  #42
little2576
little2576's Avatar
Would it be possible to replace the pics in the DIY: remove bumper, Replacing FOGS, DRL, REVERSE, HIGHBEAMS, and SIGNALS in LED please ?
AlexDev (07-21-19)
Old 05-29-17, 10:57 AM
  #43
aneidiaz
aneidiaz's Avatar
Please fix the pics in the very beginning. They were good before. Please it would help so many members. As to we take these components out often and try to tackle this area DIY style for many. I hope they can fix it! Thank you CL
AlexDev (07-21-19)
Old 06-15-17, 08:21 PM
  #44
WeetoGee
WeetoGee's Avatar
None of the photos are showing up.
Hex357 (12-20-17)
Old 01-05-18, 07:13 AM
  #45
LJGS300
LJGS300's Avatar
Can someone fix the pics at the beginning?
Quick Reply: DIY: remove bumper, Replacing FOGS, DRL, REVERSE, HIGHBEAMS, and SIGNALS in LED
