Remote Start Problem in 06 GS300
Old 01-07-10, 03:00 PM
Justawajz
Justawajz's Avatar
Default Remote Start Problem in 06 GS300
Hey guys, I hope somone here can help me out. I put a aftermarket remote start in a 06 gs300 and when I hooked the battery back up I have a number of probems. The message center displays to check the vechile stability control. The the light for the auto adjusting headlights is flashing.. That's not it... Also the power door locks do not work on the key fob or the door switch. However if the push button ign. is turned on the locks will function on both door controls just not the key fob. I dont think the keyless would work with the Ign. on anyway as a saftey feature. I also had some issues with the windows not working at first until they were reset. Now I'm no hack and double checked all wires and they all check out to be hooked up correct. I even unhooked every aspect of the remote start and I still have the same problems. Were prob gonna end up having to take it to the dealer to get scanned but I just wanted to know if anyone heard of any similar issues. Any help would be helpful. Thanks guys.. Justin
Old 01-07-10, 05:41 PM
passnu2
passnu2's Avatar
what wires did you cut? sounds to me like you tapped into the wrong wire? my set up I can use the OEM remote/fob or the remote start fob.
post back with more info.
shoneeko
07-22-17 08:25 PM
Japmand
11-13-15 09:03 PM
iGotSwag
12-25-12 06:22 AM
AYEmike
06-08-08 03:53 PM
Quick Reply: Remote Start Problem in 06 GS300
