Spacers on GS460
Spacers on GS460
Hi guys
I wanted a more aggressive stance on my car, so I decided to put on 25mm spacers and hopefully give me an indication on to how much lower my car will sit when I do decide to lower it.
The spacers i got were from TS Sportsline, they are hubcentric and bolt onto the hub and then the OEM wheels bolt onto them.
Unfortunately, my car shakes above 60mph. The smoothest ride is at around 55mph.
I took them off this morning, but I really liked the stance of the car with the spacers on.
I have 2 question/:
1. Why does the lexus shake like that with spacers? I have 30mm hubcentric spacers on my BMW E60 and it's fine.
2. Aprt from installing aftermarket wheels, what are my option to get a wide stance with OEM wheels? Will I be safe with 15mm spacers? Or will it still shake?
Any input would be highly appreciated.
I attach some pictures I took before removing the spacers.
I have 2 question/:
Are you hand torquing the wheels back on? if your using a gun that can cause a shimmy. do your wheels need hub rings, or is your center bore the same as your factory wheels. I have Ichiba V 1 10mm on the front and H&R 5mm on the rear and my car rides smooth. I can t believe that you have used 3 different brand spacers and they all are fudged up. Good luck!
The Sportsline 25mm had no hub rings. And were not the right bore size. So chucked those out!
The V2 Ichiba 20mm came with rings, but were slightly larger than the hub bore. So chucked those out.
The V1 10mm are the ones with longer studs. These also came with rings. And they fit tight and snug into my wheels which also came with hub rings.
If it doesn't turn out to be a torque issue, could it be the studs? Is it possible that the studs were not installed properly? Don't they usually correct themselves in line once torqued?
It's definitely a possibility, however I think u would notice by looking at the studs if one or more of them weren t straight and from what I understand if u don t get those studs in right they will spin when u go to take off the lug which is a nightmare!! Like said try hand torquing everything in a star pattern, just this could solve your problem!
