Finally...Fsport Wheels, TTE Springs and Nitto Tires - '08 GS460!!!!
Old 03-11-10, 08:48 PM
  #61
Leeladisky
Leeladisky's Avatar
Been so busy, haven't had a chance... will post more.
Old 03-11-10, 10:50 PM
  #62
*Batman*
*Batman*'s Avatar
Mate - can you answer my question as a fellow GS460 driver? You're pretty much the only person I know who can answer this.
How are the springs? Do they create a BMW like ride (soft over bumps but grippy in curves) or is it like an Audi ride (firm and jarring on bumpy or rough surface roads)
also does the factory AVS still adjust the damping between firm and normal?
Old 03-11-10, 11:39 PM
  #63
rominl
exclusive matchup
rominl's Avatar
i can say for sure the avs will still adjust the dampening. as long as you are with stock shocks, avs will still work
Old 03-12-10, 05:19 AM
  #64
*Batman*
*Batman*'s Avatar
I'm no suspension expert so you are saying the avs works on the shocks, and changing the springs doesn't affect that?
Old 03-12-10, 06:01 AM
  #65
Rain
Rain's Avatar
Looking good
Old 03-12-10, 07:00 AM
  #66
*Batman*
*Batman*'s Avatar
Do lowering springs make the ride stiffer? I find it needs to be more supple in normal, but with same or less amount of body-roll when shocks are set to sport.
Old 03-12-10, 08:58 AM
  #67
rominl
exclusive matchup
rominl's Avatar
correct, avs works by turning and thus adjusting the dampening on the shock (at the top of the shocks). so changing springs won't have effect on it
lowering springs will affect ride for sure. how much it affects, that depends on the springs of course
imho, springs might not reduce roll too noticeably. if you want to reduce roll without sacrificing too much ride, sway bars are the right way to go. f sport is coming out with a fix on the bushings for the sways it seems, that might be what you want to look at
Old 03-12-10, 09:43 AM
  #68
*Batman*
*Batman*'s Avatar
Thanks, Henry. Do you have a suggestion on how I can soften the ride when AVS is in normal mode? I still find it rides too rough on bad roads (I mean rougher than my old BMW 330i with sport package).
Old 03-12-10, 12:28 PM
  #69
rominl
exclusive matchup
rominl's Avatar
have you tried in comfort mode, does it help? or it's giving you too much sacrifice on the roll? if the ride in comfort is good, then maybe the sways will help you gain back the handling while keeping it in the softer ride
the characteristic of the system is basically a combo of the stock springs and shocks together, and a lot of times a different shock might help. but of course you lose the avs feature.
Old 03-12-10, 01:19 PM
  #70
*Batman*
*Batman*'s Avatar
Unfortunately the GS460 doesn't have a comfort mode. Just normal and sport.
Old 03-12-10, 01:55 PM
  #71
rominl
exclusive matchup
rominl's Avatar
oh, sorry about that, i must have mixed it up with the air suspension on ls460 @_@
i think in your case it's just really the characteristic of the stock setup itself...
Old 03-12-10, 02:10 PM
  #72
*Batman*
*Batman*'s Avatar
Yes. I wish the GS460 had LS460 air suspension.
Old 04-29-10, 12:14 PM
  #73
Slamking18
Slamking18's Avatar
FYI... I just got off the phone with Carson Lexus (l-tunedparts.com) and they said the TTE's are no longer being imported in so they are unavailable. Unless any of you guys know of other websites that can get these, it looks like we are stuck with Tanabe, Eibach, F-Sport, or Tien in which none of them have tested with the GS460.
Old 04-29-10, 01:37 PM
  #74
sherwoodgs
sherwoodgs's Avatar
please post better pics, i am very interested in this setup.
Old 05-01-10, 11:05 PM
  #75
designo
designo's Avatar
The Eibach springs are very comfortable, and the drop is perfect.
Quick Reply: Finally...Fsport Wheels, TTE Springs and Nitto Tires - '08 GS460!!!!
