Tyre Air Pressure Sensor Problem.....
Hi Guys,
I have just install my 19" 2 piece rim to my GS350.
And due to the design of the rim, i unable to install my tyre pressure sensor, so now, the warning light and hazzard light is keep on showing.
Thus, would like to check with friends here, do you face this problem as well. and how to you solve it.
Thanks
MY
Thanks
MY
A member on another forum made a pressure container out of PVC pipe and end caps, put a tire stem on one of the end caps, dropped the TPM sensors in the pipe, sealed everything up, and then pressurized the container and put it in the trunk. Go to this site for more detail: https://www.clublexus.com/forums/is-...pipe-bomb.html
Good luck
Good luck
tpms sensors
I bought a extra set of tpms sensors from Ebay. Discount Tire mounted tpms sensors inside my Auto-Couture 3 pc rims for me. What they did was band the sensors inside the rims with a clamp similar to a radiator hose clamp. They charged me $50bucks for the hardware and install when I purchased tires from them. If you choose to go this route remember to write down the code#s on each of the sensors.
