Diy rotors and pads replacement
I tried my best looking for some DIY for replacing my rotors and pads on my 2006 GS300 AWD, but with no luck. Any quick links or references? If available.
I can help what are you looking for?
here is the rear pads / caliper that should be the same on your rear: LINK This was done on my IS350. The rear brakes have a pivot, loosen the one bolt and they will swing. You can then just tap off the rotor on the rears. Let me see if I have pics of this from my GS.
Your front caliper is different then my IS and GS are since they had the OEM big brake caliper. I would think your fronts should pivot just like the rears do.
I am aware of many of the regular details when doing a replacement, but is there any thing I should be aware of when replacing ads and rotors? For example, will the caliper piston pushes back or does it need the special tool? I am not looking to bleed and so on.....Also, will things such as a rear brake emergency brake cable need to be loosened on these things? Or is it just simple. I need wrenches sizes and do I need to reset anything once all is done? Thanks
One more question please. I am also paining my calipers using the G2 kit and will also spray some clear coat after placing the decals on. Do you think it would be less tedious to do it while the caliper is off or on the rotor? Of course I will do all of this after replacing the rotors and pads.
i would do it before u replace everything, so the new pads/rotors dont accidentally get paint on them. make sure when u clamp the pistons, u compress them slowly, other wise you risk damaging them.
True, but I am using the G2 kit which is a brush and not a spray. Also, I will tape and mask everything else so I won't take any chances. If I do it the other way around I am pretty sure my chances of ruing the paint are more because I know my self lol
just paint them with everything together. I wouldnt do it before you make the change because you can scratch it with the tools. I used the brush on in my last car and it worked great. If you get anything on the tips of the pads NO one will ever see it and it wont harm anything.
