Does ANYONE know how to turn off the Oil Mainenance Warning
I will try one last time to see if there are ANY knowlegeable people on the forum that know how to turn off the oil warning message and light on a 2007 ES 350. The procedure that is mentioned in the DIY section does not apply to 2007 models. There is no separate reset and odometer button as mentioned in that procedure. There is a DISP button on the right side of the wheel that cycles the message display on the dashboard. There is a single button the resets the Trip A/B counters and cycles the odometer thru Odo, Trip A, and Trip B.
Anyone out there have a clue?
i think there's an option in one of the menus to turn off maintenance reminders. it's one of the buttons on the 'left' side of the screen... i can't remember exactly what. please correct me if i'm mistaken o.O
Turn the car on and make sure the Trip Meter is on Trip A. Then shut the car off. Without your left leg being on the brake, hold down the trip button and then click on the start button TWICE. You will then see blank lines turn into all zero's and once that sequence is completed you would have reset the Oil Maintenance Light.
ehryciuk
ES - 5th Gen (2007-2012)
01-29-09 11:03 AM
