Cargo Net in Already Small Trunk Opening
for the 06+ GS models, i think most can agree that the trunk opening is small already. however, when i use the cargo net, it would block the opening even more, causing the opening to look much smaller and can obstruct putting in bigger objects.
just curious, how many of you actually use that cargo net and does it bother you that it obstructs the already small trunk opening?
and second question....i tried looking for alternative hooks in the trunk to hook up the cargo net deeper inside the trunk, so it doesn't block the opening....but couldn't find any other hooks for this. am i missing something?
as of right now, i took the net off....making the trunk opening MUCH larger (visually) and i definitely find that it obstructs the opening much less.
I leave my cargo net hooked up all the time. On my 07 GS, there's a second set of mounting points for the net, found just as the wheel wells curve back in to the trunk (chrome square hooks) area and directly above for the upper mounting points (tiny black curved hooks). I believe the manual shows this alternate mounting position. I like this position better than up close near the opening for it in essence divides the trunk into two sections, which keeps things from sliding forward. I'll try and post up some pics later tonight.
i couldn't find the upper mounting point hooks. i see the extra set of chrome hooks near the middle of the trunk floor, but couldnt' find the upper hooks???? i have an 08 gs 350.
I leave it hooked up all the time and find it handy for packages and items that I do not want to roll around or spill in the trunk. When I need more room it takes only a few sec to unhook.
