View Poll Results: Did you get a staggered set-up on your wheels?
Voters: 55. You may not vote on this poll
Anyone regret getting staggered wheels?
Tobe practical think of it in terms of to lower the car or not to lower the car. If its not lowered go staggered.Ifits lowered go same all the way around.Ion the other hand will probably end up going staggered with the drop.
No, you could be stager and drop it don't got nothing to do with it as long as you have the right offset on the rims. but ofcourse you have to go stager there is no other way to go on a 3GS is the best look.
Staggered FTW!
I have yet to get wheels, but my springs are coming in and I'm trying to find wheels that are staggered. Can't wait!!! As long as you get an alignment and keep the air pressure in check with the wheels then there should be no real need for tires or rotation, but everyone is different.
that's right MESCA...step into the big leagues. haha, i just did it myself and dang it looks good checking out the rear tires...EVERYONE comments on it...so if you dig that kind of attention just do it. just figure out if you want the 19 or 20's and the sooner the better if you are prepared financially to do it.
Well, I was stubborn and did the even fitment after reading about all the negatives about staggered. Getting the sidewalls the same height is important because different diameter wheels travel at different speeds. So what you have is the front wheels traveling at a different speed than the rear. Long term use would eventually affect your brakes and drivetrain...unless your car was designed for staggered....like a Porsche.
The other issue was tire rotation. After 4 years of staggering the wheels, I wanted to be able to rotate. These tires cost too much to buy a set every year or every other year.
Now that I've done it, I regret it. I'm not overly disppointed because I chose the right offsets to mahe everything sit flush. That helps bigtime. Another issue is the choice of tires. My wife's GS looks better with the even setup because her tires look wider. The Nitto Evvo's have a blocked shape making them look wide, even at 245 width. My Bridgestones have a rounder shape making them look more narrow.
I can live with the even setup but I would rather have staggered.
The GS really needs bigger wheels and lowering by an inch or more. It seems the more conservative approach is to go non-staggered with 19" or 20" wheels and lowering with tanabe springs. Opinions?
Are you concerned about early brake failure (rotors and pads) or tranny problems? Do you lower the car as well or just go staggered? How big do you like the wheels so the ride stays like a Lexus? 20"? Finally, what tires do you like with your Big wheel staggered set-up?
exclusive matchup
2005 sc430, 3 yrs, 20s staggered. never a single problem
been running 22s on our ls460l, never any issue
theory is one thing, practical is another. so many people run staggered setup on their lexus (is, gs, ls, sc), if there is really a problem, that won't be the case
as soon as you increase the size of wheels, ride will start to degrade a bit. to me, doesn't matter. at 20s, lowered with coilovers, or even my ls460l lowered with 22s, the ride are still very nice imho and people in my car don't complain. but some people they even complain about the 18s on stock suspension. so it's personal
for tires, i like michelin, very expensive but you get what you pay for. soft and quiet. bridgestone is good handling but loud and stiff, same with yoko imho.
