Body Rattles - DIY thread
#46
I has a similar squeek that went away when I pressed on the left side of the dash above the left side of the cluster (angled part). I pulled the trim piece that covers the three gauge circles out about 1/4" on the left side. It is just press fit into place - you can grab it applying outward pressure and pull toward you. Once I slid it out a bit, the squeek went away. I keep meaning to remove it completely and figure out where to apply felt or foam, but I forget about doing it until i detail the car and see it not sitting flush. I also had a minor squeek coming from the dash speaker grill on that side, but the dealer resolved that when they did the dash TSB fixes. My guess is the noise you are hearing is coming from one of those two spots.
#48
EyeKutr,
Thanks for the detailed walkthrough. I've owned my GS 350 less than 30 days and the rattling Nav headunit was driving me crazy, but not $1,500 stealership crazy. After spending $4.07 at Loew's for a roll of weatherseal, I followed your remedy last night. This AM on my drive from work not a single mouse fart came outta my headunit and I owe my new found sanity to you. Now I just need to locate the minor squeaking coming somewhere near my steering column or just above my gauge cluster.
Glad to hear it worked for you buddy
#49
I have a 09 GS 350 and i just installed a couple 10 inch subs in the back. I know, this thread is mainly just squeaks and rattles when normally driving and subs are going to exasperate my rattle problems. But just in case someone has some useful ideas, my rear view mirror is rattling pretty good. There isnt much that you can do about it physically shaking when the bass hits but i was just hoping to get rid of the sound it makes when the bass hits. I will try some other ideas iv had when i get home. Let me know if there are any common culprits for noises from the mirror.
Also, unrelated to the subs, i get a faint rattle from the plastic around my gauge cluster directly behind the steering wheel. This was happening before the subs were installed and it would happen when i hit a slight bump or a bad crack in the road. I can press down on the plastic and it seems to stop when i do that. Has anyone encountered this? Anything on either of these issues would be greatly appreciated! Thanks!
#50
#52
To fix the dash squeaks all I did was take a moderately thick soft cloth and stuffed it in the dash next to the windshield. No more noises, 100% noise free.
Does anyone know how to fix the noises from the door panels? Whenever I go over bumps or rough pavement, I hear noises. Also, when I take sharp turns, left or right, I hear a metal on metal "ding" from the passenger side door. Does anyone hear that?
#54
#55
#56
I had some rattles in the door panel when the bass hit, took it apart and used a little bit of foam weathertripping around the circular speaker assembly and it helped. I also used some between the wood panels, cant recall exactly where back there but basically between the joints.
According to your write up (a few years back - https://www.clublexus.com/forums/gs-...iy-thread.html), I just need to remove the puddle light and one screw under the plastic trim within the inside door handles. Is it similar to the rear doors as well?
Thanks!
#57
I too had squeaks everywhere you turned the dash was fixed using a 5 foot by 4 inch strip of black felt. Pushing it down between the dash and windshield solved that problem. Just make sure you don't cover up the vin number
The drivers and passenger door squeaked all around the handle so I had enough. The dealer did nothing to help so I needed to take matters into my own hands. I took the door panel off and took the entire handle assembly apart. I put sound detonating all around where the handle parts meet together. I also went around and tightened all the loose Phillips head screws on the inside of the panel. All the screws.were loose. I wiggled the rest of the panel to make sure everything was tight and rattle free. Here are a few pictures of the process. My handle is solid and not a peep comes from the door. My ML system sounds so good now that I hear the bass and not the rattles.
#58
Thanks mmade22! This was awesome! However, I tried to take the doors off last weekend and I couldn't get it off from the top. Steps I took:
1. I rolled the window down completely
2. I removed the door pocket led light and the screw underneath
3. I removed the door handle plastic piece and the screw underneath
4. I removed the screw within the round piece closest to the dash (I don't think I needed to remove this)
5. I un-clipped the bottom of the door easily (around 5 clips)
6. I tried to pull it out with no luck
7. Then tried to push up to the window opening but the door had the tendency to bend so I stopped
I could not get the door panel off of the door! What is the easiest way to actually get it off from the top? I need it off to insulate the top border of the door because that is where all the noises come (from the clips I assume) when the car is cold and I'm driving over bumps or rough pavement.
Thanks.
Thanks.
#59
#60
