Pics of New Audio system in '06 GS430
Thanks guys.....I will try and get you some more pics. The rear deck re-construction helped a ton with the bass output and turned out looking awesome in suede.
Here is a pic of the rear deck. I opened up the hole where the factory sub would normally go and refabricated a new opening where the box ports into. From the trunk it looks like a bandpass but it actually is just a vented enclosure.
No rattles in the GS now!
Thanks "Wronglane".....The system has an actual RMS wattage of around 4500 watts.
It uses the brand new T1500.1 on each sub which is over 1500 watts and a 600 watt 4 channel on the front and rear speakers .....Both amps are under-rated compared to most amplifiers.
jaxgs350: looks like an optima battery to me.
12volt: crazy ride/system!
I'm sure it must sound incredible. My hearing has never quite recovered from my early 20's with 2 12" subs so take it easy on the volume.
