any Transmission flush guides?
Old 05-24-20, 08:30 PM
ROFLsaurus
10th Gear
ROFLsaurus's Avatar
Default any Transmission flush guides?
Hey i plan on doing a transmission flush and was wondering if there were any guides on here. I have an 06 gs300. I checked the FAQ thread and i thought it was a bit weird that transmission flush wasnt on the long list of DIY's so am i missing something? i only plan on doing a drain and fill and not the actual filter replacement.
Old 05-25-20, 07:15 AM
ibidu1
ibidu1's Avatar
I would avoid doing a flush, or putting any solvents into the transmission with chemicals and machines. Just not needed, and can be bad especially for higher mileage cars.
What many will do is a drain and fill, simply drain the 2-4qt's fluid, measure it and refill that exact amount. Do this for 2 to 3 times while driving about 2-5k miles in between each fluid change. After you do the drain and fills, then you can drop the pan and replace the filter and clean the magnets inside.
ROFLsaurus (05-25-20)
Old 05-25-20, 07:19 AM
ibidu1
ibidu1's Avatar
Also after you put the new fluid in, take it easy on the first drive. Drive really slowly so that the fluid mixes throught out the transmission. Do this for a block or two!
You do hear horror stories of guys doing transmission flushes on good transmission only for the transmission to start slipping right after. Toyota are not as bad, but many transmission shops will suggest the you not do it to higher mileage unless you have an issue.
Old 05-25-20, 10:12 AM
ROFLsaurus
10th Gear
ROFLsaurus's Avatar
Thank you ibidu1 for the great tips. I worded it incorrectly, i meant to say drain and fill and that video you suggested is perfect.
Old 05-25-20, 07:53 PM
714is300
714is300's Avatar
Hey bro, make sure you know the right torque amount of the transmission fluid pan's bolt. When I did mine, I effortlessly stripped the thread where now my transmission pan's bolt spins freely, but thankfully not dripping.
ROFLsaurus (05-26-20)
Old 05-25-20, 08:04 PM
714is300
714is300's Avatar
Get this hand pump tool to fill in new ATF from the side
Old 05-26-20, 04:58 PM
ROFLsaurus
10th Gear
ROFLsaurus's Avatar
Thank you for the advice bro. I'm gonna be very cautious when i deal with the filter pan bolts because i dont believe theyve been touched ever since my wife bought the car (maybe even before, if ever). I didnt even take the torque amount into consideration. This will save me alot of headaches.
While i have you guys here! is it worth it to change out the swaybar bushings even if the car doesnt seem to have any issues? I dont have any history on the car. Ive looked at them earlier today and they all seem intact. Theyre dry looking but i didnt see any cracks or anything.
Old 05-27-20, 03:32 AM
ibidu1
ibidu1's Avatar
I wouldnt bother if its not broken, but wouldnt hurt to lube them with a good lithium spray
ROFLsaurus (05-27-20)
Old 05-27-20, 04:16 AM
gs350fan
gs350fan's Avatar
Get ready to break bolts if you replace sway bar bushings. They are M7 but M8 10,9 grade works fine in the back :lol:
Especially an older MA car.
Old 05-27-20, 10:29 AM
ROFLsaurus
10th Gear
ROFLsaurus's Avatar
What are the back bushings called? I was able to find the front bushings at advanced auto parts but the back ones don’t look the same. The fronts show up as “moog stabilizing sway bar bushings front set”.
Old 05-27-20, 11:04 AM
gs350fan
gs350fan's Avatar
I think there are two kinds of sway bars. I posted a few months ago some pics I found. The rear bushings on one type I believe have to be burnt or cut off. I think to officially replace them you need to replace the bar!!
babbles
ES - 6th Gen (2013-2018)
09-03-19 07:08 AM
GSpearlwht
Performance
03-18-19 12:18 PM
vinster29
RX - 1st Gen (1999-2003)
48
06-20-08 06:25 AM
Quick Reply: any Transmission flush guides?
