6K HID Headlamps - Installation and Before/After pics!!!!!
Old 06-11-11, 10:33 AM
  #91
neurocity
Neu`roc´i`ty
neurocity's Avatar
I did the 6000k from Xenon Depot. Ordered earlier this week and got the HID's in this morning.
Install was way easy. Blue tint looks much better.
Check out the difference on me sexy legs.
Old 06-11-11, 02:16 PM
  #92
Stormforge
executive matchup
Stormforge's Avatar
your right leg is definitely more sexier than your left leg.
Old 06-12-11, 12:04 PM
  #93
XenonDepot
Former Sponsor
XenonDepot's Avatar
lol! Can't wait to see pics of the rest of the mods :-)
Thanks for supporting the vendors :-)
Old 04-25-12, 08:14 PM
  #94
nkapoo1
nkapoo1's Avatar
Smile Thanks
Thanks for these instructions, excellent details! I put a new 8000K HID bulbs, worked out great, more bluer than I wanted, next time will go for 6000K, Thanks again.
Old 04-26-12, 08:13 AM
  #95
XenonDepot
Former Sponsor
XenonDepot's Avatar
8000k is definitely blue.
Old 05-31-12, 07:41 PM
  #96
ehong33234
ehong33234's Avatar
Just took a look at my factory bulbs and here's the info on them:
Part# 90981-20021
Harison Japan D4S 35W
Old 06-01-12, 08:56 AM
  #97
XenonDepot
Former Sponsor
XenonDepot's Avatar
Yup. My understanding is that Lexus had some issues with their original D4 supplier and they switched to Harison (Toshiba).
Steve
Old 06-22-12, 12:40 AM
  #98
gsonelux
gsonelux's Avatar
Thanks y'all for the info, i got the 6000K from our vendor here and it's perfect
Old 06-22-12, 08:31 AM
  #99
XenonDepot
Former Sponsor
XenonDepot's Avatar
Enjoy! Did you take any pics?
Old 06-24-12, 07:20 PM
  #100
Gregoose
Gregoose's Avatar
Help!
So 6 months ago my driver side headlight shut off randomly while driving. I swapped the bulb to make sure it is a bulb going bad not the ballast.....after the swap bulbs now going bad on the passenger side, now it seems like its a bulb issue....so i waited another 6 months to replace the bulb due to the fact lights goes back on as long as i flickered the switch ON/OFF.
I replaced both bulb today with Xenon 6000k (D4C not D4S).......So the problem before was the passenger side bulb seems to be bad....after i installed the new bulbs on both side....after 5 minutes switched on....now the Driver side turns off? Could i have a bad brand new bulb or could it be another issue?
Any tips or help would be appreciative....thanks in advance.
Old 06-25-12, 12:47 PM
  #101
XenonDepot
Former Sponsor
XenonDepot's Avatar
Hi,
Did you purchase the bulbs from us?
Steve
Old 06-25-12, 03:54 PM
  #102
kdouglas39
kdouglas39's Avatar
When you change put the low beam on the passenger side of your 06 GS, do you hav eto remove the air filter compartment?
Old 03-09-13, 09:43 PM
  #103
DWAR
DWAR's Avatar
Great post - job was fairly easy and took about 20 minutes to change both bulbs. I used the GARAX D4S 600K bulbs (Japanese) which were recommended on other posts. They are outstanding! Two quick tips:
1- Remove the washer fluid spout on the driver's side. It's one 10mm bolt and clears the path
2- The bulb will only seat well in one direction, but it sits loose in the socket until the spring clips are re-attached. Just hold the bulb in place while re-attaching the spring clips.
Dealer quoted $600 for two bulbs and labor - job took 20 minutes and the bulbs were $90 for the pair.
Old 03-09-13, 10:27 PM
  #104
redbaron
redbaron's Avatar
Are people doing this mod for the looks, or does it increase the forward visibility at night.
I am mostly interested for when my current bulbs go out. Right now they put out quite a bit of light onto the road, but if a better lighting option (MORE LIGHT) was available, im interested.
Need to see further ahead to spot that hidden pothole waiting to eat my rim.
Old 03-10-13, 11:43 AM
  #105
XenonDepot
Former Sponsor
XenonDepot's Avatar
Higher color temperature bulbs provide you with more color but less light. a 6000k D4S HID bulb is rated at approximately 20% less light than 4300k bulbs. We carry both higher kelvin D4S bulbs and OEM 4300k Philips D4S bulbs when you are ready (both at much less than what the dealer is charging).
Steve
Quick Reply: 6K HID Headlamps - Installation and Before/After pics!!!!!
