View Poll Results: What gas do you purchase for your car?
Premium Only - I need all the ponies!
215
74.65%
Midgrade Only - Not primo but better than regular
24
8.33%
Regular - It's all the same to me
32
11.11%
Depends - Sometimes I feel like a premium, sometimes I don't
17
5.90%
Voters: 288. You may not vote on this poll
Merged 3GS Fuel Threads - Is it OK to use REGULAR gas Instead of PREMIUM?
Old 01-28-15, 04:29 AM
  #286
Stoodo
Stoodo's Avatar
Originally Posted by LoveThatV8
I was a poor college student with a NEW tundra back in 2004 and so I stuck 87 in the tank and it ran like shat...
The 2004 Tundra was rated for 87....
Old 01-28-15, 06:22 AM
  #287
LoveThatV8
LoveThatV8's Avatar
I already knew that but thanks for checking
As ive said it burned quicker, got some pinging and defeated the purpose of gas so i upped using 91 and it solved my issue, plus the Toyota techs advanced the timing each time i changed the timing belt (3 times).
Old 01-28-15, 06:24 AM
  #288
Stoodo
Stoodo's Avatar
My point was, if I had an engine that was rated to run 87, it damn well better run properly on 87.
Old 01-28-15, 06:52 AM
  #289
Gotcha350
Gotcha350's Avatar
These are sport sedans...granted not high performance but I just don't understand why you would want to lessen the performance any...it does make a difference...the good thing is that DI helps cool the combustion chamber so it helps reduces the chance for damage...
Old 01-28-15, 07:11 AM
  #290
worker
worker's Avatar
But if it run better on sea water, would you use that instead of following the little sticker behind the gas cover saying use only 87?
Old 01-28-15, 07:13 AM
  #291
worker
worker's Avatar
Originally Posted by pman6
disconnect the battery to reset the ecu. Should be clean slate for use with premium gas.
If you don't mind the horsepower drop, keep using regular.
maybe I'll try it one day. But for now I have many other major fix. Like the exhaust line is getting rusted through. Lots of rust down there.
Old 01-28-15, 08:04 AM
  #292
TRD_Power
TRD_Power's Avatar
My parents have an '03 Tundra that also says to use 87 on the gas door, which it will run on, but not nearly as well as 92. Pretty sure it's all a gimmick to help sell the vehicle to those who are more concerned with the MPG. Dad tried 87 in it once, and it ran like crap compared to 92... However, it still ran
Old 01-28-15, 02:27 PM
  #293
sonnyhood
sonnyhood's Avatar
Here Premium has 2 grades, 95 octane and 98 octane.
So i use 95.
Which is what my fuel cap says, premium only.
98 i put in now and then
Old 01-29-15, 02:59 PM
  #294
LexusLive
LexusLive's Avatar
So i use 95.
It only wants 91, though, aren't you just wasting money by having to put 95 or 98?
Where do you live that you have 98 Octane?
The highest I can buy here in GA is 93.
Old 01-29-15, 03:23 PM
  #295
Stoodo
Stoodo's Avatar
Your answer can be found here.
http://en.wikipedia.org/wiki/Octane_rating
Australia: "regular" unleaded fuel is 91 RON, "premium" unleaded with 95 RON is widely available, and 98 RON fuel is also reasonably common.
Bottom line RON vs AKI when measuring octane.
Old 01-30-15, 05:11 AM
  #296
sam12345
sam12345's Avatar
I Notice on my car that with Costco premium it runs better than with sams premium. Maybe it's psychological but now I only use costco. I believe costco has more additives but that should have no effect on performance short term only long term in that it keeps the engine cleaner
Old 01-30-15, 10:00 AM
  #297
worker
worker's Avatar
Maybe I should try premium elsewhere. The 2 tanks premium I tried were Costco.
oh, BTW about disconnecting and reconnecting battery. If you know about electronic/electricity. That initial spark is not good for electronic. It recommend to always leave the battery connect to buffer that spark.
Old 09-25-17, 12:25 PM
  #298
LOLjasonW
LOLjasonW's Avatar
Default Premium Vs Regular
So I was strollin through the forum and I have a pretty simple question .......... I think
I have always used premium in my 06 Gs300, I have heard mixed answers on here about using premium only. Some say premium only some say can use regular with no harm.....I was under the impression that it was premium only.......Anybody know the answer, or at least know the effects of long term usage. MPG, Performance anything......TYIA
Old 09-25-17, 03:08 PM
  #299
MX73
MX73's Avatar
I know for one, you won't get the sulfur "rotten egg" smell with premium fuel. Reduce performance is another. On a vehicle that has direct injection only, premium tends to reduce (not eliminate) the amount of carbon build on the back side of the valves since it burns a little more "complete" than regular fuel.
I wouldn't advise using regular fuel unless you really have to.
LOLjasonW (09-26-17)
Old 09-25-17, 04:28 PM
  #300
Propulsion
Propulsion's Avatar
Premium....
Quick Reply: Merged 3GS Fuel Threads - Is it OK to use REGULAR gas Instead of PREMIUM?
