Removing Nav screen of the 2006 GS(Pics)
Old 11-06-07, 11:10 PM
  #46
quezacotl
quezacotl's Avatar
Question
Originally Posted by VVT-i
Run the bypass wires underneath and connected them to the switch. Sorry, for the poor picture.
You are the MAN . What are the wires that are attached to the switch? The (K46 pin #14 'purple' VSS wire) and the (K46 #23 'yellow' Parking Brk wire) or the (h1, pin #13 pink VSS wire; which is Pin #16 white w/ silver dots on 07' GS models)? Thank you so much!
Old 11-07-07, 07:43 AM
  #47
EyeKutr
EyeKutr's Avatar
diagram here in post 24 or 25
https://www.clublexus.com/forums/sho...d.php?t=274051
Old 11-04-08, 01:56 PM
  #48
blckwidow
blckwidow's Avatar
anyone live in texas willing to help me with this? don't want to do it myself. i want to do the dvd mod. pm me. thanks.
Old 08-25-09, 01:52 PM
  #49
lexus4jess
lexus4jess's Avatar
Man,I need this mod.Need Help doing it.
Old 08-25-09, 03:11 PM
  #50
STP
STP's Avatar
Need help as in someone doing it for you in your area?
or
DIY/ Tutorials?
Gotta be specific my man.
Old 08-25-09, 04:07 PM
  #51
EyeKutr
EyeKutr's Avatar
The entire DIY is a sticky in the forum, PM me if you want it done and are local....
Old 08-26-09, 07:58 AM
  #52
IXI187IXI
IXI187IXI's Avatar
yea if anyone in the philly area needs help you can PM me. i pulled mine apart enough times as it is.
Old 10-12-09, 04:29 PM
  #53
cwchill
cwchill's Avatar
GREAT POST! Worked like a charm. It's important to use the little white gear switch to move the shifter into Drive, otherwise your car will stay on and its not good idea to make connections if installing the Data System override with the power on. There is really no need to pry the system as mentioned, I just kind of grabbed and gently pulled with my thumb in the mouth of the casette player.
Old 12-09-09, 09:53 AM
  #54
BinaryJay
BinaryJay's Avatar
Quick question (posed in another thread, but...): Is it possible to reach in to the back of the nav unit without removing the unit itself by taking out the glovebox (for a ipod/usb module harness connection) or are we pretty much limited to the whole nav unit removal procedure?
Old 12-09-09, 10:39 AM
  #55
EyeKutr
EyeKutr's Avatar
from my experience, you need to remove it to connect anything back there
Old 12-09-09, 11:16 AM
  #56
rominl
exclusive matchup
rominl's Avatar
i say not a chance. it's way too tight and there are brackets and such in the way too
Old 12-09-09, 11:59 AM
  #57
TWong350
TWong350's Avatar
Agree with above. No way possible. It's very tight to even try that.
Old 12-09-09, 12:49 PM
  #58
IXI187IXI
IXI187IXI's Avatar
theres very little room back there and even if you were able to do it, i doubt you'll be able to figure out how to plug the harness back in. it only takes about 5 mins to pull the nav unit.
Old 12-09-09, 05:06 PM
  #59
alwayzspeedin
alwayzspeedin's Avatar
i am trying to removel my navi and i only see two 10mm bolts , one for each side...? the instructions say 4 10mm nolts 2 on each side my car is a 07
Old 12-09-09, 05:44 PM
  #60
rominl
exclusive matchup
rominl's Avatar
there are 4, 2 at the bottom and 2 midway, both on the sides. same for all yrs
Quick Reply: Removing Nav screen of the 2006 GS(Pics)
