Sunroof gap
Old 07-27-03, 10:52 AM
SeattleGS400
SeattleGS400's Avatar
Default Sunroof gap
I just joined the club ("new" used GS400), and I was wondering if anyone knew if I can adjust the sunroof alignment. My sunroof has a 1/8" gap on the front right side of the sunroof (it does not touch the metal body). If anyone can help out w/ any information--if it can be adjusted and how--I would greatly appreciate it.
Thanks for the help and I look forward to the wealth of info here on the board.
Old 07-31-03, 08:50 PM
SeattleGS400
I'm going to order a factory manual, but is there anyone with information on this topic so that I can get this alleviated soon? It would helpful if someone could pass the info on--thanks.
Old 08-01-03, 07:41 AM
JacobT
JacobT's Avatar
It can be adjusted. I had mine adjusted by the dealer after they replaced the weather strip. If you tilt up the SR, you'll see adjustment screws on both side. It's a tedious process, I saw them driving my car in and out the dealership several times to test the wind noise.
Old 08-01-03, 08:54 AM
SeattleGS400
Thanks for the info--I'll tilt up the sunroof, and take a look at the screws (I assume that this will allow me to adjust the front right of the sunroof to be moved forward)? On my old Maxima, I could adjust it (but didn't need to) by removing the 2 side plastic covers on the bottom of the sunroof, and loosening the bolts to allow me reposition of the glass around. I thought that the GS400 sunroof would be similar--but didn't want to start the endeavor unless that was the procedure. Thanks for the info.
CrackerJac
12-23-23 08:53 PM
Broncosi
03-30-19 12:54 PM
642jdub
04-17-13 07:24 PM
kennylexsc
04-24-06 06:37 PM
omaha_lex
04-23-05 02:01 PM
Quick Reply: Sunroof gap
