2000 gs300 no crank no fuel
Old 03-05-17, 08:51 AM
Dutch3605
Dutch3605's Avatar
Default 2000 gs300 no crank no fuel
Engine swapped, was running and driving, then there was a coolant leak from the rear hose on top of the engine that wasn't clamped properly, since that leak no crank no fuel. Removed starter, got it tested at the part store and it works.. swapped the relay, didn't change anything, so I jumped the relay with key in the on position, it's cranking but not turning over. Cracked the fuel line, put the key in on position and not getting any fuel pressure. Checked all fuses, all are good, EFI relay is good. So basically I turned the key, no crank no fuel, but the gauges light up
JoshwDavis
03-13-19 08:20 PM
easports91
06-16-14 05:39 PM
bmarsh757
GS - 1st Gen (1993-1997)
12-25-10 04:35 PM
Quick Reply: 2000 gs300 no crank no fuel
