2001 GS430 CEL P0301 and P0308 After Knock sensor replacement
Old 02-13-17, 08:30 AM
ElGuapo76
ElGuapo76's Avatar
Default 2001 GS430 CEL P0301 and P0308 After Knock sensor replacement
I replaced the knock sensors (no more P0325 and P0330) this weekend but am now getting CEL with P0301, P0308 error codes. Misfire on cylinders 1 and 8.
I also replaced the MAF sensor.
Checked the wiring, clips and connections and all looks normal.
I also changed the oil, because when I checked the oil there was too much oil so I drained it and put fresh oil in (5.5qts). Would too much oil cause the coils to cause this issue?
was not having this issue prior to knock sensor replacements.
I removed the intake in one piece, so didn't have to remove the fuel rail.
Last edited by ElGuapo76; 02-13-17 at 08:30 AM. Reason: Added year and model to title
Old 02-13-17, 01:32 PM
kevin3344
kevin3344's Avatar
Did you use true OEM knock sensors?
Old 02-14-17, 09:23 AM
ElGuapo76
ElGuapo76's Avatar
I did use OEM sensors. I have yet to get the p0325 or p0330 codes.
I'm going to switch the coil pack from cylinder 8 with cylinder 5 to see if the behavior follows to #5, if it does then I'm sure it's the coil pack. If not, then i'll have to look at the injector or harness clip.
Old 02-14-17, 09:27 AM
kevin3344
kevin3344's Avatar
Yeah, I'm not sure. I had my knock sensors done at the dealer (pricey to be sure) but haven't had a problem since. Keep us posted on what you find out.
Bullitt180
10-12-19 02:08 PM
fairmaidon
RX - 1st Gen (1999-2003)
03-15-15 07:09 PM
lexusgal60
20
12-23-11 07:42 AM
1stGS300
07-18-11 02:52 AM
xenonrider
01-01-10 03:29 PM
Quick Reply: 2001 GS430 CEL P0301 and P0308 After Knock sensor replacement
