Completely Silent V8 Engine? Help!!
Old 01-30-17, 05:03 PM
AlexBasix
AlexBasix's Avatar
Default Completely Silent V8 Engine? Help!!
Hey guys. I was just wondering if there is a way to make my 1999 lexus gs400 v8 engine sound 100% silent. I heard somebody call it i think "Nightcrawler". If that makes any sense lol.. Any help is appreciated.
Old 01-30-17, 05:50 PM
plex
1UZFE/2JZGTE
plex's Avatar
Wow, subscribed to this one.
Old 01-30-17, 07:13 PM
mate01
mate01's Avatar
I'm not sure if it's possible to make any engine whisper quiet?
Old 01-30-17, 09:12 PM
clintdaddy
clintdaddy's Avatar
It is pretty damn quiet to begin with!!
Old 01-31-17, 07:02 AM
newgsman
newgsman's Avatar
Just throw away all the keys
The following 3 users liked this post by newgsman:
firelizard (02-01-17), plex (01-31-17), tiguy99 (01-31-17)
Old 01-31-17, 04:17 PM
ThomasGS4
ThomasGS4's Avatar
Was going to suggest turning the key counter-clockwise in the ignition, but that works too.
Old 02-01-17, 02:48 AM
GS400V8
GS400V8's Avatar
Well the stock intake has some pretty agressive helmholtz resonators for noise cancellation. I took it apart before and The the black box connected to the intake splits into two chambers to cancel noise. The first smaller chamber kills one frequency that is attached to one vacuum line. The other larger section in the box kills a different frequency with two vacuum lines. I actually did the opposite and fabricates a restrictor plate to make them louder while still preserving the stock black box and vacuum abilities. .
The exhaust is very quiet as well, there is just no room left for any additional mufflers.
Old 02-01-17, 05:01 PM
firelizard
firelizard's Avatar
100% silent combustion engine is 100% impossible. Darn you, physics. Best you could do is add insulation like kitabel said, and make sure every moving part is in optimal condition and properly lubricated.
Old 02-01-17, 07:28 PM
eicca
eicca's Avatar
any details available on your intake box mod?
Old 02-04-17, 04:20 PM
AmanO
AmanO's Avatar
****, my alternator is louder than my engine.
Old 02-08-17, 09:33 PM
lextout
lextout's Avatar
just turn the car off, problem solved.
Old 02-08-17, 10:48 PM
Meowmr2
Meowmr2's Avatar
Just do what enterprise did back in the day
Old 02-09-17, 04:22 PM
burteboy
burteboy's Avatar
Default silent v8 engine.
Check your pulleys ,valve clearance , timing belt idlers and tensioner. May help reduce noise.
Old 02-09-17, 06:42 PM
Ecohman
Ecohman's Avatar
Default Boise noise cancelling tech
The gov is supposed to have tech that works like Boise noise canceling head phones to make helicopters silent. GS400, easy peasy.
Old 02-27-17, 10:11 AM
GS400V8
GS400V8's Avatar
Eicca, For the intake mods basically I used a dremel drill to cut a plate sized section out of the bottom of the resonator chamber so you couldn't see it. Then I cut another plate out of plastic to replace it, except drilling two small holes to allow vacuum to the attached three hoses on the other side of the resonator box. There are two holes drilled in the plate because the factor box splits into two helm holtz chambers within the large resonator box. One side feeds one hose, and the other side feeds two. Now instead of air easily entering the chambers, it is now restricted probably by 30x the amount, while still providing the same or if not more vacuum to the hoses.
I did this for more noise, as well as retaining the factory resonator and hose attachment points. There is also a perfect outlined section on the lower air box, that points towards the passenger wheel well that I cut out. The other side of the air box as well as the hood air vent blocks engine heat from this side.
Although, I might just delete the resonator box off the stock intake entirely and running three vacuum lines, I just need to fabricate another plate with three fittings. I don't like the way after market intake filters look, so this is another reason why I am doing this. The resonator box blocks to much of the engine bay now that I have redone it. I painted the whole upper intake manifold, valve covers, cam covers, strut bar, and custom etched and painted the metal service plate on the throttle body with the "L" logo.
Quick Reply: Completely Silent V8 Engine? Help!!
