2000 lexus gs 300 2jz ge vvti ecu pin diagram
hello guys, i have been searching for a few weeks now online, and nothing. looking for a ecu pinout for my computer and if and how to disable the immboilizer or what does the immboilizer kill ( fuel or spark ). i have searched and searched.... seems like no one has every did wiring work on a gs300. any help would be great .
sorry, my project is a 2006 ford crown vic 2jz swap, i got the 2jz ge vvti from the 2000 lexus gs 300 , and so i got all the wiring from the donor car, but i want to install only what i need to just hear the motor fire up, even if its for a second. the motor was running perfect before i removed it, and i feel everything is plugged back in right
The immobilizer prevents both the fuel pump from running and the injectors from firing. But you get spark. So even if you manually power on the fuel pump it still won't fire the injectors.
Since your running a GE a JDM 97-00 S300 JZS160 Engine Ecu without immobilizer would be a drop in pnp option to bypass the immobilizer all together. But since your are GE-NAT you could also run the more common 97-05 V300 JZS161 ecu as well.
Since you have an aftermarket FFIM and Throttle body you will run into limp mode issues with the throttle motor/PPS disconnected though.
