Radio cuts out when applying brakes.
Old 11-05-16, 09:07 AM
akafixture
akafixture's Avatar
Default Radio cuts out when applying brakes.
This use to happen mostly when it would rain, but its starting to do it when its dry. When I apply the brakes the radio will cut out, then come back on with the Lexus logo on the navigation screen. The battery is about 2.5 years old. Could this be the alternator starting to go out?
And at night I have noticed the gauges will dim slightly when he brakes are applied as well.
Thanks for any help.
Jonathan
Old 11-05-16, 09:16 AM
Dave Mac
Dave Mac's Avatar
I had something kind of similar to this happen a few years ago and before tearing into my dash as the tech was advised to do by Lexus, he first replaced the battery and the problem was solved. It never happened again. I would certainly try the battery replacement first regardless of how it test.
Dave Mac
Old 11-05-16, 12:19 PM
Mr Jokster
Mr Jokster's Avatar
Yes, definitely a possibility. Pressing the brakes not only activates the brake lights, but turns the master cylinder on. All together it puts a load on the electrical system. Yes under normal circumstances all is fine, but with the large dip in voltage, it can effect the weaker systems. Can either be your battery or your alternator. As stated above, best to try the cheap easy thing first
Old 11-08-16, 09:19 AM
akafixture
akafixture's Avatar
I will check the battery out. It gave me issues about 2.5 years ago, so maybe this one is going too. My car just stopped on me when I was parked. I was able to restart it and got it home. Need to head out to the parts store today.
Jonathan
Old 11-08-16, 11:02 AM
lexo98
lexo98's Avatar
Jonathan
My GS started doing weird things when my yellow top Optima shorted out internally
Old 11-08-16, 11:13 AM
akafixture
akafixture's Avatar
Must be the battery again. Thanks lexo98.
Old 11-08-16, 11:22 AM
Mr Jokster
Mr Jokster's Avatar
I always overlook the easy stuff... Check your connections at the terminals too
Old 11-08-16, 05:58 PM
akafixture
akafixture's Avatar
I just checked and man the positive cable is loose. I tried to tighten it and it will not budge to tighten it. Sanded the connections and tried to tighten it. it wont tighten. heading out now to the parts store in my 88 Mitsubishi starion ( my 88 starion that still starts).
Will re post back when I am done tonight. (i am done now.) Have a 4 year old with a broken leg.
traducian
07-01-14 04:26 PM
goldlexus9
11-02-08 09:27 PM
400 Degrez
Suspension and Brakes
03-03-08 12:01 PM
gaunt
14
07-24-07 02:54 PM
2turbo4u
GS - 1st Gen (1993-1997)
05-04-07 10:22 PM
Quick Reply: Radio cuts out when applying brakes.
